M696 Gauges
Started by Venom51, August 14, 2013, 06:58:38 AM
Venom51
This sort of revives an old question that I couldn't find a new answer to.
Due to a build-up of pressure in my front brake master cylinder, brake fluid squirted out onto my gauge cluster. I didn't see it on there until it was too late.  [bang] The corrosive nature of the fluid stained my cluster. Thankfully, it's only on a portion of it. I can see most of the important data.
So...is there any way to ADD an analog gauge to the existing gauges? I don't want to replace them but would like to add, at a minimum, a speedometer. I can read the speed but it can be difficult. I'd like to add something above the existing digital gauge so that it doesn't cover the data. If anything, higher and pointing a bit up would actually add to visibility for me.
Any ideas? Thanks for the help!
ChrisK
Maybe add a picture so we all can imagine it.
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
Venom51
You mean a picture of what I hope can be done? I just want to add an analog gauge like this:
ChrisK
I kind of meant what your gauge looks like now, so that we can see the damage and maybe imagine for ourselves what a solution could look like.
But I get where you're going, and there are plenty of aftermarket gauges available. A lot use magnet sensors to pick up speed readings so they're pretty easy to install.
1998 M900
Not analogue, but I have one of these Vapor things on my DR... works very well..
or there's this (no FHE)..
if you're dead set on analogue there's this (no FHE here though)..
... but if it was my 696 I think I'd be looking to fix the original instrument cluster.
Venom51
Here's a pic of the damage:
Thanks for all the suggestions and replies. I'm going to try and find a used plastic housing. I should be able to remove the existing one and replace with a used one. This doesn't mess with any of the electrical and hopefully, the price will be right. The real problem is actually finding one. Ducati doesn't sell it as a part. They only sell the entire unit and that is $$$$.
Someone suggested I try headlight cleaner (I think it's a 3M product) but I'm not sure it'll work with this kind of corrosion. Plus, I don't want to mess with it too much and ruin it further. Anyway, thanks again for the suggestions.
ChrisK
If that's just a clear piece of plastic over top of the LCD screen you could probably take it apart and cut your own replacement out of a sheet.
1998 M900
Stormtrooper
Wow...how did it squirt out of the master? was the top plate loose?
Venom51
Quote from: ChrisK on August 16, 2013, 09:53:58 AM
That's a good thought. I'm not sure that's how it's designed though. I'll take it apart this weekend and check.
Venom51
Quote from: Stormtrooper on August 16, 2013, 10:48:59 AM
There's a small hole on the left side of the master cylinder. When the pressure built up, it began squirting out as a very fine line. I'm guessing the pressure inside the master pushed the bladder up. As I was trying to figure out what was going on with the brakes, the brake lever tightened more and more until it felt like the brakes were locked. I pulled over to inspect. I couldn't figure out why the brakes were squeezing on the disc. So, I loosened the top plate and fluid escaped over the rim which released the pressure and allowed me to get home.
It wasn't until I got home that I realized every time I had been squeezing the lever, it was spraying onto the gauges. Weird.
NVTanner
This was supposed to be my next winter project, so I'll bring it up here. If you remove the electrical connector on the back of the display there are 8 torx screws that will allow you to separate the front trim from from the back electronics portion of the display. Then you can replace this plastic lens and put it back together.
This is what I was planning to do this winter. The previous owner of my monster used silicone on the edges so water wouldn't leak in but it now looks like shit with all the dust and scratches. So I'm planning on replacing mine this winter.
I hope this helps getting you to get yours looking better.
'11 Monster 696, Pantah Body Parts, Ohlins DU 737 Rear Shock, ST4S Five Spoke Marchesini 180 conversion rear wheel, H-Comp Exhaust, Speedymoto top triple clamp with riser, 1098 Showa suberbike adjustable forks, ST4S Five Spoke Marchesini front wheel, Braking.com 748R 15mm offset wave rotors Rizoma Conical Black Handlebar, Woodcraft Racing Rearsets, 848 Black Wet Clutch Cover, 796/100 Kick Stand (added 1"), 999 Black Preload Adjuster.
nickshelby500kr
I have the disassembly instructions in my rebuild thread if you search for it.
Venom51
Quote from: NVTanner on August 16, 2013, 11:35:28 AM
Great info, thanks!  [thumbsup]
Venom51
Quote from: nickshelby500kr on August 16, 2013, 12:17:22 PM
Thank you!
