February 20, 2025, 11:56:45 AM
How do you detach the monoshock spring & pivot arm from the swingarm? '05 620
Topic: How do you detach the monoshock spring & pivot arm from the swingarm? '05 620 (Read 928 times)
The ModFather
Duck Off
Monster Magnet
August 21, 2013, 06:36:54 PM »
I'm looking to detach the stock Sachs monoshock spring from the swingarm on a 2005 620. Any advice or guidance here would be greatly appreciated.
Thanks!
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
Re: How do you detach the monoshock spring & pivot arm from the swingarm? '05 620
August 21, 2013, 06:48:07 PM »
See the threaded part? there is a nut at the top that adjusts tension...and removes the spring.
The ModFather
Duck Off
Monster Magnet
August 21, 2013, 07:37:06 PM »
Sorry I should be more clear. I'm not trying to remove the spring itself I'm trying t remove the Swing arm and the shock and pivot rod connect to it so I need to detach them to remove the swingarm. I'm pretty sure I just need to get an metric hex in through the hole on the side of the swing arm and remove the bolt that goes through the swingarm that they attach to before I take the swingarm off. I just want to see if there's anything I should be aware of or if I'm on the right track here.
2008 848 Track Bike
August 21, 2013, 08:16:17 PM »
Remove top bolt, remove bottom bolt, through the hole you noted in the swing arm. Be aware that the bottom of the dog bone is held on with the same bolt. Parts will fall out of the dog bone, keep them in order. You do need to support the rear of the bike in a way that will keep the bike from collapsing on you, not by the swing arm. This is a good opportunity to check and lube the swing arm bushings, rocker arm and dog bone.
Enjoying the ride
August 22, 2013, 05:26:49 AM »
I used 2 jack-stands with a modified support so that the passenger foot rests would go into the tubes and a little extension to support the OEM rearset
something like this, but, actually, where are mines?
