Power Commander piggy-back on Termi ECU ???
Started by Jimmy480, August 24, 2013, 07:35:43 AM
Jimmy480
Hi Guys,
Been told a PC piggy-backing on a Termi ECU will smooth out the throttle (Monster 1100 EVO).  Is this worth the dough? as quite a bit of work to get it in.  What are the pros/cons?
Thanks for any advice,
Jimmy
oldndumb
Ditto re ungeheuer and  Raux's comments!
I took it one step further and included an AutoTune with the PCV.
Downside to installing both in an 1100 Evo is finding enough space if installing both units. I had already removed the flapper valve actuator, so that space was available. Also moved the traction control ecu connector out of the way; the harness is long enough to do that. Would have been a problem otherwise because stacking both units together was too tall for under the seat as verified by modeling clay compressions. If installing only the PCV, underseat space is sufficient.
SpikeC
 There is a bit of extra space under the tank as well. I stuck a fuse block under there on my 09 M1100S that allowed a bunch of switched and unswitched circuits, and did not even use the space that I used on the other Monster that I had where the relay for the jacket heater went!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
oldndumb
Quote from: SpikeC on August 24, 2013, 04:28:06 PM
Could be, but the Evo has less under tank space available due to ABS.
Plenty of room for PCV + Autotune module under my tank skins  ;D
oldndumb
Quote from: ungeheuer on August 24, 2013, 10:38:57 PM
What accommodation do you have for connecting to your computer?
Quote from: oldndumb on August 25, 2013, 02:03:19 PM
Off with the LHS lank skin, in with the USB lead.
For as often as I feel the need, it's convenient enough for my liking.
Yogi
I was under the impression the PC had no effect on small throttle openings where most if not ALL of the surging happens. Best thing I did was remap with the Rexxer. Absolutely no surging at all and smooth throttle response. I have a fuelling chart from when I had it on the dyno its very close to perfect. I have homologated termis and hi flo air filter.
Stormtrooper
My Rexxer reflash smoothed out a lot of the fueling issues but its still not perfect.  Still get a lot of decel popping and the throttle can still be snatchy <3500RPM, can't help but think I'm leaving a few ponies on the table too.  I have a PCV in the garage that is on the to-do list.  Once installed it I'll have a custom dyno tuned map made that will hopefully rectify the aforementioned issues.  I'll be sure to post up a before and after PCV dyno thread for those interested.
Yogi
Decel popping can sometimes be caused by very loose fitting silencers like the Termis mine wobble around on the system pipes, basically you suck more air in around the gaps, try sealing the silencers onto the system pipes with some quality exhaust sealant.
What bike you got Stormtrooper? I didn't think you could ride a monster below 3500 mine is like a buckaroo below 3500. I' agree throttle is much more sensitive but I don't think I am down on power with my map and setup. You are right of course your best bet is always a custom map on a dyno, do you have access to the Rexxer map editor or a hop with it? But if your doing that why would you want the PC?
Do you know which map you have from Rexxer? Maybe we could set up a thread to trade maps I have the C1 map.
Quote from: Yogi on August 26, 2013, 08:15:14 AM
Yup. It's been discussed at length  :).
Quote from: ungeheuer on August 24, 2013, 07:49:23 AMI have a PCV, its the second best option available IMO  [thumbsup]
Some light reading for you..
http://www.ducatimonsterforum.org/index.php?topic=42213.0
http://www.ducatimonsterforum.org/index.php?topic=41934.0
PCV itself isnt able to control fuelling in closed loop, you are correct.  But the PCV (for Siemens ECUs at least) is supplied with either an optimizer module or individual optimizers (depending on if you have the older or newer version) which do effect the fuelling within closed loop.  I actually works well.
Having your ECU custom reflashed, is however even better IMO (although this option isn't available to many of us).
Duc796canada
Anyone have a dyno tuned Map for Leo Vince slip-on with stock ECU they are willing to share?
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
oldndumb
Quote from: Stormtrooper on August 26, 2013, 09:45:01 AM
........ Still get a lot of decel popping and the throttle can still be snatchy <3500RPM, can't help but think I'm leaving a few ponies on the table too. .........
With PC V and AutoTune remapped, mine will run smoothly at 3K rpm in third gear. It will accelerate smoothly from there, but wants a smooth throttle application. It also allows use of sixth gear on the interstate. I am extremely pleased with it, and I can be quite sensitive and critical of bike drivability. BTW, stock air cleaner with a Competition Werks can. Currently fabricating a MWR clone air cleaner set up.
