April 27, 2024, 04:42:45 AM
Idle adjusting screw?
Topic: Idle adjusting screw? (Read 1527 times)
SpikeC
Spike in PDX
August 29, 2013, 07:02:12 PM »
I saw a picture of the idle adjusting screw somewhere recently and I can't remember where. Was it around here somewhere? The motor is from a 2007ish multistrada.
My Bimota's idle seems to have slowed just a bit, it probably need a new motor, it does have just over 3 thousand miles on it......
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
Re: Idle adjusting screw?
August 29, 2013, 08:15:21 PM »
Idle is traditionally adjusted with the air bleeds, but the motor in your bike may have an idle air valve.
Pictures of the TB would help.
May just be a bad battery.
SpikeC
Spike in PDX
August 30, 2013, 09:13:24 AM »
Well, it does seem to be the original battery............
Spike Cornelius
PDX
1965 T100SC
SpikeC
Spike in PDX
August 30, 2013, 11:10:00 AM »
Ok, I know where the throttle stop screw is now, so I am assuming that the air screws are the brass ones on the outside of the throttle bodies, that are easily accessible. I shall try nudging them in or out a touch and see what effect that has.
I can get a factory diagnostic kit for the Walbro ECU from the Bimota guy in NC for 400 bucks that will let me play with the parameters if I get ambitious enough.
Spike Cornelius
PDX
1965 T100SC
August 30, 2013, 11:37:44 AM »
Walbro ECU.... well that's handy for ensuring next to no help from folks here.
Opening the idle air screws 1/4 to 1/2 turn should pick the idle up.
Sometimes that doesn't work if it's running lean already.
SpikeC
Spike in PDX
August 30, 2013, 11:42:16 AM »
Thanks for input, Speed, every little bit helps! I have a digital shop manual for this puppy that seems to have a pretty good section on the Ecu business, I have not looked at it yet butt will see what there is to see in there.
Spike Cornelius
PDX
1965 T100SC
