More aggressive ergos: clip-one vs. Suburban Machinery bars
Started by asherrick, August 29, 2013, 08:58:33 PM
asherrick
From searching around the forum it seems like most people that have gone to clipons have done a 3" rise. Any idea how this compares to SM bars? Compared to stock (I actually have a Rizoma bar, so the taper is different)?
'09 M1100s
If you get clip ons with replaceable risers (Woodcraft) you can buy other heights to adjust later on OR buy 3" and slide them down on the fork tubes IF you want to lower them.
Comparing to Rizoma will depend on which Rizoma model you have, but the usual Rizoma bars have about the same sweep angle as Suburban - quite a bit higher than stock though (~2")
On the new monsters the tanks dictate the rises
zero come below the tank to the frame
3“ hit the stock air intake indents
anywhere inbetween limits yout turn radius
SpikeC
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
ute
I have the SM bars ..love um , just rotate down to find your "sweet spot" but as said above you must delete the locate pegs in your switch gear ..no biggie
now that being said I have not used clips on my Monster just on the Gixxer , but like you said you want a middle ground not a Superbike
I say go with SM if you don't like you can always sell on here
asherrick
I just realized that I completely forgot something...my DP steering damper that attaches to the handlebar mount. I'll need to lose that if I go with clipons. Hmm...I'm thinking that I may start with the SM bars and see where that gets me.
'09 M1100s
seanster
I like these Apex clipons.  Just rotabe the bars and it will give you different angle, plus there is raise options of 3 or 4"
http://www.apexmfg.com/products
Stormtrooper
I run Woodcraft 2.5" rise on my 796 - I would recommend them.  The forward riding position made handling and turn-in more precise without adding too much weight on the wrists...a good compromise IMO.  With new adapters you can go from zero rise to 3" rise without changing the entire setup.
These pics may help you:
Stock bars vs Woodcraft 2.5" (a 5" drop in grip location + more natural angle)
Stock flipped bars vs Woodcraft 2.5" (a 2.5" drop in grip location)
Fully installed:
asherrick
Fantastic photos, Stormtrooper! That really illustrates the height difference.
'09 M1100s
Quote from: Stormtrooper on September 04, 2013, 09:50:25 AMI run Woodcraft 2.5" rise on my 796 - I would recommend them.  The forward riding position made handling and turn-in more precise without adding too much weight on the wrists...a good compromise IMO.
+1.  Whilst I'm running 3.5" Swatts (and previoiusly 2.5") my experience echos 'trooper's.
Quote from: asherrick on September 04, 2013, 10:53:35 AM
Yup, a perfect visualisation, good work Stormtrooper  [thumbsup] [clap]
Rudemouthsky
Get the Suburban bars because they're made in CLEVELAND, baby.
asherrick
Thanks for your help, everyone! I selected the Suburban Machinery bars. So far I like them but I have a few issues to sort out. The first one is that the stock mirrors are now completely worthless. Is my only option a bar end mirror? I generally don't care for the looks of them.
'09 M1100s
teddy037.3
#27
Quote from: asherrick on September 17, 2013, 07:03:23 PM
you could try aftermarket stalk mounted mirrors; there's all sorts of height/angle to them, you may find one that'll work with the lower bar position.  or is the problem due to rotation of the controls?
:edit:  I ran 1st gen SM bars on my 620... re-drilled the holes for the controls to better suit how I wanted the bars angled.  FWIW, I loved them; perfect for my height/reach vs. the stock bar
Steve.In.Atlanta
What I've liked the most about bar end mirrors is the convex mirror let's me pretty much see behind me which is good on the road to make sure my ass isn't being ridden.
2005 Monster S4R
2001 Monster 900S (stolen)
asherrick
Quote from: teddy037.3 on September 17, 2013, 08:19:59 PM
I'm not sure that stalk mirrors will be tall/high enough with the lower bars. That's the problem that I'm having with the stock mirrors.
'09 M1100s
