February 24, 2025, 07:54:41 PM
Please Help
More aggressive ergos: clip-one vs. Suburban Machinery bars
Topic: More aggressive ergos: clip-one vs. Suburban Machinery bars (Read 15002 times)
asherrick
August 29, 2013, 07:58:33 PM »
I have a M1100s and am looking for a more aggressive riding position. I had a 1198s and don't want to go that aggressive with it but somewhere in between. I'm thinking that clipons, like Speedymoto Tall Boys, or the Suburban Machinery bars might fit the bill. Has anyone ever compared the two?
Any other thoughts? Thanks!
'09 M1100s
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Re: More aggressive ergos: clip-one vs. Suburban Machinery bars
August 29, 2013, 09:04:14 PM »
No FHE with Suburban Machinery bars (I do like the look of those though), but I have run Speedymoto Tallboys and subsequently swapped those out for Swatt clipons with 3 1/2" rise. Swatts are no longer in production, but Woodcraft makes something which does the identical job as my Swatts.... and the Woodcrafts also look nicer too IMO.
Although I found Speedymoto Tallboys more appealing to the eye that the Swatts I ultimately ended up with, I wasnt happy with the lack of sweep-back offered by the Tallboys.
Here's my experiences if you're interested....
http://www.ducatimonsterforum.org/index.php?topic=21407.0
....for the purposes of comparing you can pencil in Woodcraft in place of Swatts...
One thing to consider is the cost of replacing the stock top triple if you decide to go with clipons (you could continue to use the stock triple, but with no bars mounted atop, it'd look a little naff IMO).
Last Edit: August 29, 2013, 09:10:30 PM by ungeheuer
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Privateer
August 29, 2013, 10:17:53 PM »
the SM bars aren't that much lower, from my experience, altho they're rotated down more which made my wrists happy
before:
after:
S2R 800 '07
August 30, 2013, 12:30:40 AM »
Clip ons typically have a 7 degrees down angle.
Suburban doesn't.
Stock sweep is 18 degrees.
Suburban is 24, typical clip ons at ~30.
Clip ons will feel about the same as your 1198, but higher, depending on your choise of risers.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
August 30, 2013, 01:40:50 AM »
Quote from: stopintime on August 30, 2013, 12:30:40 AM
I feel as though I'm pushing thru corners with much better precision with clipons than with regular handlebars.... don't really understand how that is actually possible ... other than placing my weight/input more forward, a little lower.... but that is certainly how it feels.
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
suzyj
Does my bum look big on this?
August 30, 2013, 01:43:15 AM »
I obsessed over just the same option when I swapped my forks for 998 ones. I ended up going with zero-rise woodcraft clip-ons above the triple. It's a really comfy position. Aggressive without being nuts. Heaps of angle and very narrow.
If you're patient, you can even cut the bar mounts off your existing triple so it doesn't look sucky.
August 30, 2013, 03:13:43 AM »
I have a 696 and run woodcraft zero rise under the triple with the 1" wider bars they have
In this pic you can see my setup, a typical Monster and a 1198.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
August 30, 2013, 03:30:49 AM »
Quote from: suzyj on August 30, 2013, 01:43:15 AM
Nice job
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Enjoying the ride
August 30, 2013, 04:57:29 AM »
<snip>
suzyj,
did you bore out the top triple or replace it with a 998 one? I understand you cut the supports for the steering bar, but, the 998 are wider or am I still a bit sleepy?
btw, I have that same configuration, Woodcraft 0 rise on top of the top triple . . .
suzyj
August 30, 2013, 05:04:29 AM »
Quote from: Darkmonster620 on August 30, 2013, 04:57:29 AM
suzyj,
It's the stock 695 triple, bored out. The 998 triple is quite different.
Enjoying the ride
August 30, 2013, 05:06:45 AM »
Quote from: suzyj on August 30, 2013, 05:04:29 AM
Thanks !!!
August 30, 2013, 07:34:31 AM »
Very similar to my setup. Very streetable. I'm 5'9" and I can comfortably sit up with both hands on the bars.
asherrick
August 31, 2013, 11:38:18 AM »
Thanks for all of the feedback, guys (and gal)! My goal is to get more weight over the front weight and a little better high-speed stability. Again, I don't want to turn this into a Superbike, so I'm looking for that middle ground.
Privateer, thanks for the before-and-after pictures of your SM bars! Do you happen to have a picture from the top of the bike showing the bar position in the clamp? I'm curious to see how you have it oriented.
With the M1100s the clipons would need to be mounted
below
the triple. It would seem like a zero-rise setup would be too low, and much lower than the SM bars. Am I right?
'09 M1100s
August 31, 2013, 11:54:47 AM »
Yes
SpikeC
Spike in PDX
Reply #14 on:
August 31, 2013, 12:46:26 PM »
Wen I mounted the SM bars on my 1100S I needed to rotate then down a bit to work right for me and that put their hole for the left side switch cluster in the wrong place. I had to cut off the peg and add a bit of black tape to secure the cluster.
I liked the position quite a bit, it was close to my BMW R1100S.
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
