Need Front End Modding Opinion
Started by ChrisK, September 10, 2013, 07:31:45 AM
ChrisK
Quote from: Darkmonster620 on September 10, 2013, 08:39:24 AM
beats new calipers ???
I suppose, yeah.
Can anyone give an opinion on if this is the route to go over a GSXR setup?
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
Quote from: ChrisK on September 10, 2013, 08:42:00 AM
I suppose, yeah.
The Gen-1 Monster chassis' do not like larger forks than 41mm inverted units.  I've done some SBK fork swaps on customers Gen-1 bikes and the handling changes a good bit with the stiffer front end (as in the flex which used to be absorbed by the forks in now transferred to the frame and therefore felt by the rider).  Some of the customers didn't feel it, some did.
If you've got the adjustable 41mm Showas and they're in good shape, then my vote is to rebuild the forks first and then look into the brakes.  Upgraded rotors help and there are a LOT of different pad compounds out there for the Brembo 30/34 calipers.  Stainless braided lines are a MUST if you haven't done them...
ChrisK
Quote from: Duck-Stew on September 10, 2013, 09:57:02 AM
Okay thank you.
Yeah it seems like I don't give enough credit to updated brake lines over the OEM ones, didn't realize they can make that much difference. Regardless of the lines though I still need to get my calipers moving the way they're supposed to. Also, I imagine severely undersprung forks can make braking power feel very limited, is this true? As in, the front end dips very hard under hard braking and so it doesn't feel as solid as it should.
1998 M900
don't forget to change out your steering bearings as well
ChrisK
I inspected those and re-greased them when I had it all apart. Did these things come stock with tapered bearings? If not, some previous owner had some put in.
1998 M900
Crappy fork springs/damping for your weight really upset the bike under braking. All the unsettled front end feedback can be confusing re your brake issues.
Having your forks set up with correct springs and damping for your weight is one of the best investments you can put into your bike. With that sorted you might better feel what the brake issues are.
That said, +1 on braided lines and good pads being important upgrades. I also got 999/S4RS radial master cylinders and that made a big difference to feel. I run the older 4 pot  2 pad Brembo calipers and I am very happy with the combination. Your 4 pad calipers should give more bite than mine, but mushy brake lines, unsuitable or contaminated pad material and issues with your master cylinder could undermine that.
FWIW, I have a K4/5 Gixxer 750 track bike. The Previous owner had soft fork springs, bad brake fluid (probably badly bled) and the wrong pads in it. The brakes and front end felt like crap. Had correct springs and valving for my 210 riding weight fitted by a good suspension guy and I changed the fluid (with careful bleeding) and selected appropriate pads and they're great.
Very interesting comment on the 41 Vs 43 mm forks issue re feel and feedback. My brother and I both have noticed a big difference in chassis/front end feel and feedback between his 2001 M900 and my 1995 M900.
ChrisK
Quote from: koko64 on September 10, 2013, 11:55:53 AM
I agree getting the correct internals for my forks will make a world of difference. That said, I KNOW that my calipers are causing my "pulsating" feeling while braking. I go through the process of cleaning the pistons, getting them behaving the best I can, and there is definitely less pulsating effect afterward.
I have the same 2 pad calipers as you, with Nissin radial masters.
Cool, according to your track bike account it seems I would have to respring GSXR forks if I were to go that route anyway. I believe the K4/5 series forks are the "vintage" I've been researching as possible replacements for mine, so that's very good to know.
1998 M900
ChrisK
Where is fork diameter measured? The upper triple area?
1998 M900
My apologies, I misread (it's 5am), and thought you had upgraded to 4 pad calipers. Of course you would need adaptor plates (or later forks) to mount 65mm 4 pad calipers off a 999.
You will love braided lines with a radial m/c.
What shape are your discs in?
Quote from: ChrisK on September 10, 2013, 12:12:10 PM
At the hardchromed part. As a 98 model yours are 41s oem.
ChrisK
My discs appear to be fine. I don't have any real experience with telling if they're wore out. I seem to remember reading that 4mm is the minimum for material width on these rotors? Well they're thicker than that. Never feel a wobble or shudder or anything so I don't think they're warped.
1998 M900
Quote from: koko64 on September 10, 2013, 12:10:37 PM
It's a finer point, but the '01 was the only frame with the larger tubes, 12mm engine bolts, 43mm forks AND the hoop rear suspension.
After riding (and owning) many 2002 & up Monsters, an 848 and now a '99 framed SS1000 I can notice a HUGE amount of frame 'wiggle' on a friends '97 when I take that for a toodle.  Not that it's a bad handling bike, just that I will NOT push that chassis like I used to when I had my '99 M750.  But, that's just me.  YMMV...
ChrisK
Just got the Racetech springs installed, correct for my weight. Just from the short ride I took on them tonight I can already tell this was probably the best mod I've done to my bike. Braking confidence is through the roof in comparison to the old springs.
1998 M900
