February 24, 2025, 08:26:48 PM
Need Front End Modding Opinion
Topic: Need Front End Modding Opinion (Read 3945 times)
ChrisK
September 10, 2013, 06:31:45 AM »
Over the last couple of weeks I've been learning all sorts of new things about front end dynamics, love this forum for that reason
My 98 M900 has the adjustable Showas, however they're severely undersprung for my 210 pound self. I'd really like to get this sorted out one way or another and I'm seeking opinions on which way you guys would go. I should also say that I'm having difficulties getting my OEM calipers to work correctly, seems no matter what I do I can't get all the pistons to move at the same rate and it's causing "pulsating" when braking as well as decreased braking power.
Option 1: Purchase racetech springs that are sprung for my weight and just keep working on the calipers, withe the confidence that they'll eventually come around. Racetech springs are $114.99 I believe.
Option 2: Fit my bike with GSXR forks/calipers from around 2005-2008. To make this happen I figure:
forks - $200
calipers - $50
rotor spacers - $13
caliper spacers - $15
brake line kit - $70
pads - $50
TOTAL - $398
Can anyone come up with a good argument to justify a $400 investment into option 2 over option 1? I'm worried I would still have undersprung forks with the GSXR's, however I've heard that the valving is much better, so that's a plus, and I would assume the calipers would be better.
Anyway, just brainstorming right now and I appreciate the help guys.
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
ChrisK
Re: Need Front End Modding Opinion
September 10, 2013, 06:32:55 AM »
I also just looked and realized that racetech gold valves would be $169.99. So combined with the springs I'd still be far less than a conversion to a GSXR setup.
I should also add that I definitely do not have a money tree in my backyard.
1998 M900
September 10, 2013, 06:41:23 AM »
you could upgrade your front calipers to sbk calipers as well
ChrisK
September 10, 2013, 06:55:57 AM »
Quote from: Raux on September 10, 2013, 06:41:23 AM
As in calipers from a 999 or something?
1998 M900
Enjoying the ride
September 10, 2013, 06:58:01 AM »
Quote from: ChrisK on September 10, 2013, 06:31:45 AM
forks - $200
calipers - $50
rotor spacers - $13
pads - $50
TOTAL - $398
do you have the goldline 4 pot calipers? do you have the coffin master? if not mistaken, don't believe me, yoyodine has a rebuilt kit for these calipers but, on the master side, I would recommend an upgrade to a radial one, either accossato, brembo or why not, magura . . . and replace your lines, all of them . ..
or as raux said, upgrade to 4/4 calipers, that is, 4 pot/4 pad . . ..
ChrisK
September 10, 2013, 07:06:15 AM »
Yes I have the goldline 4-pots. I recently upgraded to a Nissin radial master.
1998 M900
ChrisK
September 10, 2013, 07:07:21 AM »
Also, I've looked into the rebuild kit and they were like $60 per caliper I believe, IF they have them anymore.
1998 M900
Enjoying the ride
September 10, 2013, 07:07:58 AM »
then maybe, it would be time for either a rebuild or upgrade . . .
are you using your original rotors? are they clean?
is this happening after the accident?
Enjoying the ride
September 10, 2013, 07:08:36 AM »
Quote from: ChrisK on September 10, 2013, 07:07:21 AM
if they have them, get 'em if you want to go this way
imho, is worth it
ChrisK
September 10, 2013, 07:16:04 AM »
Woah, nvm, just the seal kit is $50 per caliper. If you find a kit with the pistons it's much more expensive, over $100 per caliper.
1998 M900
Enjoying the ride
September 10, 2013, 07:18:26 AM »
Quote from: ChrisK on September 10, 2013, 07:16:04 AM
just get a very fine sandpaper, like 1200 and clean brake fluid to use to wet sand the pistons to clean them, this is how we 'refurbish' the pistons in the 3rd world . . . and no complaints up to now from no vehicle owner
ChrisK
September 10, 2013, 07:27:48 AM »
Is it okay to remove pistons and then place them back in the original seals? I'm assuming yes.
1998 M900
Enjoying the ride
September 10, 2013, 07:34:06 AM »
Quote from: ChrisK on September 10, 2013, 07:27:48 AM
take them out, replace seals . . . clean cylinders where pistons move . . .
ChrisK
September 10, 2013, 07:36:47 AM »
Ugh, $50 per caliper for seals hurts...
1998 M900
Enjoying the ride
Reply #14 on:
September 10, 2013, 07:39:24 AM »
beats new calipers
