Bike won't start after changing fuel filter! Please help!
Started by malamikigo, September 10, 2013, 05:25:54 PM
Ddan
Quote from: rgramjet on September 13, 2013, 10:37:07 AM
Clamplite tool sounds like a good investment.  Not sure how onebcould use it inside the fuel tank.
It has it's uses but does require some room
Ducati Monster Forum at
www.ducatimonsterforum.org
Yeah on the metal efi tanks a squeeze or wormscrew clamo is probably your best bet....
Monstyr
Rather than get caught up derailing this thread I had only commented that the OE clamps could be reused with a bit of care.
Like others may have done I wasn't expecting to find these and did not want to leave my tank in bits for an hour while I went to find replacements, in any case your clamp tool seems excessively expensive when (if you know anout it beforehand) you can just buy a couple of these type of clamps for pennies.
Did the OP get his bike to run?
The two most common things in the universe are hydrogen and stupidity.
Not everyone does it the way you did.
It is far easier to remove the entire pump/filter assembly and change out the filter on the bench. ;)
rgramjet
Quote from: ducpainter on September 13, 2013, 05:31:41 PM
I thought about going that route, but with my luck......I would have done something very bad....
-Sofadriver
malamikigo
hey guys, i will post a thorough update soon.  Sorry for my lack of replies, it's been super busy with work the last few days.  There are developments though.  Will post again soon.  Gotta run for now though.
