November 26, 2024, 08:04:06 PM *
Author Topic: Brake pads sintered on not?  (Read 1233 times)
jamie2548
« on: September 12, 2013, 12:10:23 AM »
Needing to change my front pads and was wondering what the difference is and any advantage there is between the sintered and organic pads . I am a weekend rider and the odd tour. No track work. Also any recommendations on brand . There is quite a few cheap ones on ebay which comes with great sceptic thoughts Undecided
These are the ones im looking at. MetalGear Brake Pads Front L/R DUCATI 1000 Monster Dark i.e. 2003
Oh yeh 03 1000sie  Wink
« Last Edit: September 12, 2013, 12:12:28 AM by jamie2548 » Logged
braando
« Reply #1 on: September 12, 2013, 12:39:26 AM »
Best you ask Rob there Jamie, if it was me i'd say that it's a warranty issue. Make the miserable shit buy them for you plus drive down for free fitting.
Bazz21
« Reply #2 on: September 12, 2013, 01:05:31 AM »
depends what you want standard for a controlled feel or intant bite for the sintered i liked the standard for the wet if it was a daily ride i stay with the standed cause the sintered will chew the disk  hope that helps a little cheers bazz
MAX SAYS MORE WOOM WOOMS
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #3 on: September 12, 2013, 03:01:03 AM »
Hmm, what was it my mum used to say? if you can't say anything good, don't say anything at all........ so with that in mind i would recommend well known quality brands like SBS, EBC, Ferodo, all good quality pads that shouldn't squeal (use copper grease on the backing plates) and will wear the pad more than the rotor surface.
Sintered pads are excellent for track use, if you're strictly road use, organics will do fine, saving rotor life, reducing dust and lasting well, the trade off is a slightly softer lever feel and they will fade if you give them repeated hard use. The genuine pads are definitely the best option for road use but will cost more than aftermarket brands including aftermarket brembo pads.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
Bazz21
« Reply #4 on: September 12, 2013, 03:16:21 AM »
you allways say thing much better than  me on a key board paul, i liked the standed pads that cam with my bike i reckon they saved my arse thousands of times when i got into im to hot times which was  every time i went riding and trying to avoid wild life, bazz
jamie2548
« Reply #5 on: September 12, 2013, 12:35:15 PM »
Cheers guys. Much appreciated  waytogo
loony888
« Reply #6 on: September 13, 2013, 01:27:40 AM »
aww, thanks bazz
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
