February 25, 2025, 12:38:24 AM *
Pages: 1 ... 5 6 [7] 8   Go Down
Author Topic: Advice sought: New wheels  (Read 23993 times)
1.21GW
bikeless
« Reply #90 on: March 08, 2014, 07:11:22 PM »
Thanks, BK.  Overhang in the picture is just because the adjuster is loose, but when I set it in place (as seen on the sprocket side pic) there is still the issue.
All relevant parts are OEM as far I know.  Your suggestion of wrong sprocket flange is a decent candidate.  Will know more when I call on Monday.  Sigh.  So close...
BK_856er
2007 M695; 2004 749s
« Reply #91 on: March 08, 2014, 07:17:11 PM »
Not familiar with those adjusters, but you can't swap R/L sides to swap the overhang and gain clearance for the sprocket nuts?
It's frustrating now, but it'll be worth it in the end after you get everything squared away  Dolph
BK
« Reply #92 on: March 08, 2014, 08:18:27 PM »
~~~SNIP~~~
BK
Yes, that's all he needs to do, he's got the adjuster plates on the wrong sides.
If he swaps them, then he will have nut-to-adjuster clearance.
He's got 2mm nut-to-swingarm clearance, and that's fine, My M750 with aluminum swingarm and 5.5 wheel has less than that.
The brake caliper bracket has that little lip because on the OEM wheel, it sits directly against the wheel bearing.
The lip bears on the inner race, and the rest of it has clearance so it doesn't grind up the seal.
« Reply #93 on: March 09, 2014, 03:43:00 AM »
popcorn
Waiting for the Homer Simpson Doh!
 Grin
1.21GW
bikeless
« Reply #94 on: March 09, 2014, 05:56:24 AM »
 bang head bang head bang head bang head bang head bang head bang head bang head bang head bang head
« Reply #95 on: March 09, 2014, 06:55:36 AM »
We have all been there.
1.21GW
bikeless
« Reply #96 on: March 09, 2014, 07:04:25 AM »
Ok.  Got it.  Too cold to test ride so will have to wait until next week.  But here are concerns:
- Front sprocket retention plate screws.  I did at 6 Nm (per a tutorial on DMF) with some blue loctite. That enough?  I note that LT Snyder uses safety wire but I realized this late and did not have any on hand anyway.
- Chain adjustment bracket.  Due to low clearance (2mm) as noted above, I'm worried about the tendency of this to come undone and then get hit by the spinning sprocket.  I normally use zipties through the axle opening in the swingarm to secure these brackets, but due to low clearance I'm worried about doing this on the sprocket side.  I don't want to use loctite since I need to the screw to be adjustable for the chain.  Any ideas on how to secure?
« Reply #97 on: March 09, 2014, 10:24:00 AM »
You're fine on the sprocket plate screws.
In my experience, chain adjustment brackets only get into trouble if the bolts aren't snugged down after the axle is tightened.
You could drill a small hole in both the swingarm and bracket on the bottom and safety wire it, I suppose.
« Reply #98 on: March 09, 2014, 10:59:21 AM »
Ditto on Speeddogs advice.
Adjust chain...tighten axle...snug up adjusting bolts then lock nuts...ride.
thought
Everyone needs a
« Reply #99 on: March 09, 2014, 08:19:09 PM »
Adjust chain...tighten axle...snug up adjusting bolts then lock nuts... WAIT OUT THIS EVERLASTING FRIKKIN WINTER...ride.
fixed. haha
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
1.21GW
bikeless
« Reply #100 on: March 13, 2014, 12:33:04 PM »
Can any experts out there give me some guidance on torque numbers for: 1) the rear sprocket bolts and 2) the rear brake rotor bolts?  I don't my Lt. Snyder manual with me.  Also, is loctite (blue?) recommended for either of those?
« Reply #101 on: March 13, 2014, 12:40:38 PM »
Torque values for a somewhat earlier bike here... http://www.ducatimonsterforum.org/index.php?topic=373.msg2528#msg2528
Assuming they're all 8mm diameter I'd just go 16 ft/lbs.
Most use loctite on rotor bolts. I've used red or none myself. It makes an impact driver a requirement for removal if you loctite them.
1.21GW
bikeless
Re:
« Reply #102 on: March 14, 2014, 12:52:37 PM »
Thanks, DP. I have to bookmark that link for future reference.
1.21GW
bikeless
« Reply #103 on: March 14, 2014, 05:32:32 PM »
Just curious, because my bracket calipers closed during install and so I had to push the pistons back.  How many rotations should a rear wheel turn if I spin it when up on a rear stand?  I'm worried brake pads may be a little too engaged.
« Reply #104 on: March 14, 2014, 10:06:21 PM »
Opposed piston calipers will have some drag, how much is hard to explain to you on the internet.  Depending on strength and speed of your spin I would say 1-3 rotations.
Pages: 1 ... 5 6 [7] 8   Go Up
