Clutch master/slave calculation
Started by stopintime, September 25, 2013, 01:57:18 PM
I'm trying to figure out if my parts will work on a dry clutch engine and how the pull will be.
The combo in question: Dry clutch - coffin master - Yoyodyne slave
AFAIK the coffin master bore is 13mm and it's pivot to plunger distance is ~21mm
...this compared to a radial at 15mm bore to 18mm pivot (?)
From a coffin to a radial, the effect of a larger bore is reduced by the 'shorter pivot ratio'
33% larger piston against ~17% shorter pivot.
This means I move about 16% more fluid with a radial...
Usually not what people want for a street bike.
So, we buy larger bore slave cylinders - mine is a 29mm (?) Yoyodyne against stock at 26mm (?)
If not mistaken, I have 16% less piston movement at the master AND 25% less at the slave.
Is that going to be too little movement to fully release a dry clutch?
You may be on the edge.
The standard goldline masters, such as on S4, S4R are 12mm.
But the pivot distance is ~25mm.
The coffin clutch masters I have around here are 12mm.
Look up from the bottom on the front lower side of the reservoir, there's a part number like  XXXX12 for a 12mm.
I've tried to see what it says, but I can't  :P
Yoyodyne says something about a 13mm being standard
http://www.yoyodyneti.com/ProductInfo.aspx?productid=10.4670.14
I guess I have to check it out if I get around to this engine swap.
If it doesn't release, I can put on my stock slave and maybe later do the master instead.
[Dolph]
I use a flashlight, mirror, and 10x magnifier to read the number on the coffin masters
Quote from: Speeddog on September 26, 2013, 01:48:00 PM
I do that to see my computer monitor.  ;D
