'00 M750 Carbed/ Bad spark?
Started by J-Cee, September 28, 2013, 10:40:27 AM
J-Cee
I've been having rough running issues with wet plugs. I shot a quick video. Weak spark?
'00 Monster 750 Carbed
Spark looks OK.  Check the needle jets for wear.  If they look oval (use a magnifying glass if needed) replace the needles and jets.
J-Cee
Factory pro jet kit and emulsion tubes on the way. If this doesn't fix it what else could it be?
1. Leaking vacuum fuel tap (usually one cylinder)
2. Float needles not seating very well due to crud or ethanol eroding the rubber tips
3. Fouling due to using hi octane fuel in a low comp motor
Howie is correct however (an elder statesman around here) with replacing the oem needle jets, etc, they wear very quickly (sometimes in 5000 miles).  If there are other issues you have lost nothing and gained smoother running, better response and improved fuel economy. Worn needle jets are at least part of the problem and the first item to service with these symptoms.
J-Cee
Thanks guys! I'll let you know how it turns out.
memper
Factory Pro supplies titanium emulsion tubes.
J-Cee
Just realized that the ground strap from the engine to the frame was disconnected from the frame. This could definitely cause weak spark. Where does this bolt to the frame? It's on the right side behind the rear brake fluid reservoir.
Quote from: J-Cee on September 30, 2013, 07:27:38 PM
It attaches to one of the rear set bolts via a nut on the back side of the bracket.
J-Cee
Okay. I may just run a new ground straight to the battery ground.
J-Cee
Jet kit installed. Runs awesome!!
