November 28, 2024, 02:54:16 PM *
Author Topic: 2001 m600 all turnsignals and ts warning lt not working  (Read 732 times)
Radracer6
« on: September 28, 2013, 04:22:35 PM »
Hi all
Installed integrated tailight on my monster. Checked all the connections,  finished up and everything seemed kosher. I take off everything works fine and in about 5 min the turn signals stop working. I pull the seat up and i see the green turn signal wire got crimped on the seat hook and it looked like it went through the insulation and touched the metal seat hooking. Now none of the turn signals work, not front not back not even the warning light that tells you signals are on. Not sure if cause was pinched wire but i disconnected the rear signals, fuse is fine and tailght and brake still work but front  signals still do not and still no signal warning light. Any clue? Did i fry a relay?
J-Cee
« Reply #1 on: September 28, 2013, 05:23:20 PM »
That's the only other part in the circuit. Any auto store will have one. Get an electronic one if you don't want to run resistors.
'00 Monster 750 Carbed
Radracer6
« Reply #2 on: October 07, 2013, 07:34:02 AM »
I bought the Novita EP35 turn signal relay at autozone which I read is a good replacement for the stock relay, it says it's led compatible however the signals flash really fast now, I thought this relay would slow them down without resistors?
http://www.autozone.com/autozone/parts/_/N-5yc1s?itemIdentifier=6415
