February 24, 2025, 08:24:46 PM *
Author Topic: SportClassic exhaust on S2R1000?  (Read 1825 times)
eyduc
« on: October 02, 2013, 05:22:27 AM »
Has anyone tried to fit or modify to fit a SportClassic exhaust to a S2R1000?   The motor is the same but the swingarm is different.  So, that is the possible area that will have interference if swapping exhausts.   Actually, looking at it again, the SC rear header will hit the S2R shock.  Maybe,  a combination of exhausts parts will work?   Particularly, I like the single upswept Arrow exhaust made for the SC.
Like this:
caperix
« Reply #1 on: October 02, 2013, 05:57:46 AM »
The shock location will be the bigest issue in putting sport classic exhaust onto a monster, The 2 into 1 system you showed may be possible if the mid pipe is in the same location as a monster, you just may have to make a new rear cylinder pipe.
I always loved the look of the Zard system for the sport classics
http://www.google.com/imgres?sa=X&biw=1024&bih=596&tbm=isch&tbnid=tit_p1CUCdyRxM:&imgrefurl=http://www.motographite.com/2011/07/ducati-sport-1000-zard-exhaust.html&docid=Hu6P0gOmCxuYgM&imgurl=http://3.bp.blogspot.com/-LWc6WJI9NRE/TiLUjbQm2jI/AAAAAAAAAes/RKPN5nBcsZ0/s640/ducati-sportclassic.jpg&w=625&h=417&ei=eyVMUtGSLIPE9gTc1IGQCQ&zoom=1&iact=rc&dur=2&page=1&tbnh=137&tbnw=198&start=0&ndsp=15&ved=1t:429,r:0,s:0,i:81&tx=98&ty=81
but there would be no way to put it on a monster due to routing.
eyduc
« Reply #2 on: October 02, 2013, 06:11:43 AM »
That's what I figured.  But, I think it's worth a shot.   I'd use the SC front header, midpipe & muffler.  Then, [just like you noted] starting with the stock S2R rear header, fab the remaining header to the mid-pipe.   I may try it this winter, if I get a TIG setup.   Just kicking around ideas for now.  I won't do anything soon.  Just curious to see what others have done.   There's gotta be someone that's successfully done it.
teddy037.3
« Reply #3 on: October 03, 2013, 08:54:14 AM »
you'd most likely have to fab a new hanger, as well... but, it sounds like you're a handyman, so it shouldn't be a big deal  chug
eyduc
« Reply #4 on: October 03, 2013, 09:30:14 AM »
I just found out that I already posted about this before.   I have been away from the forum too long.
Here is a pic of a bike I posted before:
It appears the swingarm is not a Monster SSS though.  Not sure if the muffler is from an SC.
teddy037.3
« Reply #5 on: October 03, 2013, 11:11:31 AM »
multistrada swinger/headers maybe?
« Reply #6 on: October 04, 2013, 05:07:47 PM »
Looks like the same header/megaphone that's on my SC.
« Reply #7 on: October 06, 2013, 08:34:01 AM »
Bike looks like an S2R1k to me.
S2R 800 '07
« Reply #8 on: October 06, 2013, 08:39:29 AM »
Yes, it can be seen through the wheel. It might look different around the shock, but that is probably a hugger or some cover....
