August 31, 2024, 03:14:27 PM
OFFICIAL: Closed Loop ECU mods
24
25
26
Topic: OFFICIAL: Closed Loop ECU mods (Read 338038 times)
caperix
Re: OFFICIAL: Closed Loop ECU mods
Reply #360 on:
March 13, 2020, 03:56:56 PM »
You said you have a dp ecu installed, most of those disable the o2 sensors. Have you tried removing the rapid bike and seeing if the faults return. I have never been a fan of the piggybacking ecu tunners, but the quick shifter limits your options. Is the evo a merrelli ecu?
RRossi
Reply #361 on:
March 18, 2020, 05:19:51 PM »
Quote from: caperix on March 13, 2020, 03:56:56 PM
Tomorrow I will remove the RB and reinstall the PCV with the 02 sensors back in like it was before and see what happens, if its good, I will buy a PC Q/S and the balance of life will be restored …..
The only issue also is if I do run the O2 eliminators I will need to retune it and even though I don't pay for tunes its a time thing?
Stay Tuned! (Pardon the pun)
RR
Reply #362 on:
March 18, 2020, 09:32:40 PM »
Evo has a Siemens (spelling) ECU. With these ECU's (including the DP version), the O2 sensors stay on unless you fit O2 Eliminators or get a reflash.
Another device is the O2 Optimizer. O2 Optimizers work inline with functioning O2 sensors to trick them while O2 Eliminators deactivate them (whether they are removed or not).
The beauty of Optimizers is that you dont need a retune and they trick the ECU to set the AFR around 13.6 in the closed loop section of the map until the PCV takes over in the open loop section of the map.
Eliminators do require you to map over them, so dont expect them to work like an Optimizer.
RRossi
Reply #363 on:
March 19, 2020, 10:14:09 PM »
Quote from: koko64 on March 18, 2020, 09:32:40 PM
Got ya, well so far so good, have swapped back to the PC5 with 02 sensors pluged back in and its running fine and no codes, but will be going on a longer ride tonight so that will be the true test, only drama is not having a Q/S but if this works I will have to buy a stand alone Q/S, so now the hunt is on for a unit that is good and easy to set up, any advice?
RR
Reply #364 on:
March 20, 2020, 01:38:12 AM »
I thought PC made one to tap into the PCV iirc.
https://www.dynojet.com/quickshifter/
Last Edit: March 20, 2020, 01:49:44 AM by koko64
RRossi
Reply #365 on:
March 20, 2020, 05:28:18 PM »
Well an update, the PCV runs perfect, no codes and all is good,
so there is something wrong in how the RB works with the hyper, a real shame as I have spent thousands in trying to get it right but that's life I spose, you win some you lose some.
Only option now is to put a Q/S in and be done with it.
RR
Reply #366 on:
February 09, 2021, 09:40:37 PM »
Tested PC O2 Optimiser against the Smartmoto O2 Eliminators on a modified M1100Evo today. The bike has a dyno tuned PCV, velocity stack intake kit, DP ECU, Termis and deactivated exhaust servo.
The test covered the closed loop rpm/throttle range that these devices deal with. One completely excludes the information from the O2 sensors and one works with the sensors to trick the ECU to be more generous.
The difference in how the respective devices worked with ECU was quite vivid. The PC Optimizer provided very strong acceleration and immediate and very aggressive throttle response. The bike surged forward spinning up very quickly with small throttle adjustments. Small throttle turns yielded big surges of torque. Very gratifying. The bike went from angry to rage.
The Smartmoto devices allowed a dyno tune map to apply to closed loop rpm/throttle and was very soft and smooth, a bit like urban or wet mode that some bikes have. This made throttle control easy and safe. The motor felt flat in comparison, but with easy throttle modulation and very smooth power delivery.
So wild Vs mild.
I went with wild
Last Edit: February 09, 2021, 09:58:45 PM by koko64
Charlie98
Marveling at my
McKinney, TX
Reply #367 on:
February 11, 2021, 07:29:23 AM »
That's cool!
I would still like to tune my ECU, but I haven't quite made the mods you have on my '13 796. I don't know if you can qualify a 796's torque as either angry or rage, but it would be fun to have a little more response.
Dennis
2013 M796 ABS
Reply #368 on:
February 11, 2021, 09:35:35 PM »
What mods were they again?
Charlie98
Marveling at my
McKinney, TX
Reply #369 on:
February 13, 2021, 08:40:20 AM »
Quote from: koko64 on February 11, 2021, 09:35:35 PM
Simple enough... Arrow slipons, which helped the bottom end immensely, a Duc-ee servo eliminator. I actually have the mid-pipe from a 696, so I can get rid of the flapper completely... it's in the To Do pile.
It still has the factory intake, which I'm reluctant to fool with. I have a second ECU I picked up, I want to send it off and have it remapped, it's my understanding that some maps will eliminate the O2 sensors completely.
Dennis
2013 M796 ABS
Reply #370 on:
February 13, 2021, 11:13:17 AM »
Yes O2 delete is an option and mapping applied to that rpm/throttle % zone.
Charlie98
Marveling at my
McKinney, TX
Reply #371 on:
February 14, 2021, 07:44:41 AM »
Quote from: koko64 on February 13, 2021, 11:13:17 AM
I guess I have to axe... what, exactly, are the downsides to leaving the O2 sensors?
Dennis
2013 M796 ABS
Reply #372 on:
February 14, 2021, 11:40:24 AM »
If they are programmed out of the equation with a reflash then they are fine just sitting there. You can remove them and fit bungs.
The other route is to actually use them via the Powercommander route. The Powercommander/Dynojet O2 Optimizer unit actually makes them work really well imo. I have tested that route with a PCV dyno tuned for performance and have been very happy with the results on two Siemens ECU controlled Evo 1100 motors. The two Powercommander modules work together, one covers the closed loop zone and one covers the open loop zone and I am a convert to this method.
Others have gone the reflash route and are happy. I think the reflash route works best if the map is created for your bike via a dyno tune.
Reply #373 on:
April 27, 2021, 04:46:26 AM »
One other thing, I read recently that the O2 sensors can be damaged if left in without being connected. I can't verify this at present. If this is true then it's best to remove them and fit bungs if the reflash deletes their input.
Reply #374 on:
May 08, 2023, 02:51:52 PM »
Quote from: koko64 on April 27, 2021, 04:46:26 AM
If they're disconnected, why would it matter? If you don't want them...?
24
25
26
