Ducati monster 620ie loss of power..
Started by mr.freezer, October 13, 2013, 07:57:28 AM
mr.freezer
Hi guys.. another problem with my monster 620ie... Today i was riding when suddenly it lost power... riding about 2000 rpm.. pulling full gas and monster goes like it has not fuel... it is going like with one cylinder... I do not know how to explain it... I've checked spark plugs.. they have nice color... tank full... battery loaded... do not know what to do?? help
When was the last time you changed your fuel filter?
ab
I had similar issues in past and ended up changing fuel filter and had a loose spark plug.  Good luck
mr.freezer
I have not change fuel filter yet... going to order some... and spark plugs too
Quote from: mr.freezer on October 14, 2013, 07:14:28 AM
How many miles?
mr.freezer
38000 km... but I am owner from 32000 km...
If you didn't get any maintenance records then I'd change the filter ASAP.
mr.freezer
so.. today i've changed spark plugs... I used Denso... started it up and it goes like with one and a half cylinder.. whed i disconnet upper spark plug while engine is idling, it changes sound but keep running... when i disconnect horizontal engine stops... I do not think its fuel filter.. ordered one yesterday.. going to change it tommorow... but have anyone idea what esle can it be??
Like ab said...he had a plug wire issue.
You should check those connections, both at the coil end and the cap end.
If the connections are good, you could try swapping coils.
First do a compression or (better) leak down test to confirm the engine is good.  Compression good?  Swap the coils from the horizontal cylinder  to the vertical cylinder and see if the vertical cylinder now stops.  Do the same with the ignition wires and spark plug caps.  No difference?  Could be a fuel injector.  Oh, and change the damn fuel filter  [bang] [bang] [bang] it is a maintenance part and should be changed anyway.  Also go for a ride, hit the kill switch and coast to the side of the road.  Remove the spark plugs, take good photos and post.  If there is a good repair shop near you it might be worth it to bring the bike to them.
mr.freezer
#11
leak down test?? it started suddenly..moto had lot of power before... I do not think it has bad compression... I will change the fuel filter tommorow and try to swap coils too... now when I start it and pul the gas just to 3500rpm, it shots to exhaust..
mr.freezer
:D I 've googled it just after you posted it...
mr.freezer
so guys.. today I swapped coils.. without result.. the same problem as before... vertical cylinder does the trouble?? what else to check??? try to swap injector, to know if there's a problem??
