LED tail light INT. turn signals
Started by bachus2001m900dark, December 02, 2013, 11:19:54 AM
bachus2001m900dark
Hello all,
I have had my ducati monster 900 for about a year now.  Previous owner installed an aftermarket tail light (led with integrated sequential turn signals) unknown brand
I was a good boy the other day before a ride and checked my rear signals.  without motor running the left worked and right did not,,,, not too long after they both would not work.   I cleaned a bunch of connections which needed to be done anyway.   and then i realized that they did work correctly but only with the motor running.
I am wondering if these lights are supposed to work with out the motor running.
I am not sure if mine did prior to me checking.
any help would be greatly appreciated.
lilmonster
The light may be a Motodynamics brand. IIRC Instructions say engine must be running for light to work properly.
seanster
Could be you have a week battery.
I had the motodynamic (same) tail light with integrated sequential turns... At first the lights worked with out the motor running,  then since I found out I need to replace my battery soon, I also found out that the turn signals only work when the bike is running.
DucDucGoos
If it is the actual taillight starting to fail, I'm pretty sure MotoDynamics (given that's which one it is) warranties their tails.
Does it have the sequential flasher, or just solid when it flashes?
Rob Hilding
#4
Just installed one, and it does not work with the engine off....
But works great while running  [thumbsup]
dufukincati
Quote from: BozcoRob on December 14, 2013, 01:35:10 PM
Just installed one, and it does not work with the engine running.....
Rob Hilding
Dellikose
Ditto to what everyone else is saying.
My carbie's MD taillight only turns on when the engine is not running, no turn signals or brighter when brake lever is pressed. When the engine is running everything works correctly.
1999 Ducati M900
