November 28, 2024, 07:54:47 PM *
Author Topic: PARTS INTERCHANGEABILITY  (Read 9299 times)
Enjoying the ride
« on: January 25, 2014, 05:59:40 PM »
The following fenders WILL fit ALL Monsters:
916
996
998
748
848
1x98
M696/796/1100
StreetFighter
MTS620
MTS1X00DS
ALL SS models
These are the ones I have been able to test on MY Monster
Must test SC fenders to make sure7
749/999 might fit, but, needs some work
Also if you have the Brembo Goldline 4 Pot axial calipers and newer Monster, HM or MTS, the brake pads are the same.
Also from what I have been able to research, newer Monster 696 & 796 use the same rotors as the 'older' 6 bolt rotors found on, 916/996/998/748,  Monsters & SS.
If you have something to add, go ahead.
freeclimbmtb
From Zero Member to
« Reply #1 on: January 27, 2014, 06:36:10 AM »
Also an important note to add is that 848, 1098, 1198, streetfighter fenders WILL fit monsters WITHOUT ABS.  The new gen monsters ABS bracket hits the inside of the new gen SBK fender causing it to warp to the left (looking at it from the front).  SBK's that have TC/ABS use a different sensor that reads pins in the rotor float rings where the monster sensor reads the slotted disk mounted closer to the axle.
On the subject of brakes, 696 has 6 bolt rotors, 796/1100 have 5 bolt.
I put this chart together for my SBK fork swap on my 796 (a thread that I STILL need to update for completion...)
I had to use 999R rotors on my 796 (5 bolt) to get the correct offset for the SBK forks and axle (15mm instead of 10mm)
Hope this helps.
(also an important note for brakes, the 1098/1198/SFS have 330mm rotors and use 5mm spacers between the fork slider posts and the brake caliper. This is important because the caliper mounting bolts are the same length, meaning withouth the spacers installed the bolts bottom out in SBK forks about 4mm before the caliper is tight.  You either need to find caliper bolts that are 5mm shorter, or have yours turned down by 5mm.  I digress...this thread is about fenders.)
« Last Edit: January 27, 2014, 06:41:26 AM by freeclimbmtb » Logged
2011 Monster 796 ABS
Enjoying the ride
« Reply #2 on: January 27, 2014, 07:30:03 AM »
Thanks for the enligthment!
I had  made this from some of the bikes that had come into the shop, so, unkess the 796 owner or PO changed something . . .
Again thanks
DucDucGoos
« Reply #3 on: January 27, 2014, 03:36:24 PM »
I have the 696 CF fender on my older monster. I like the lines of it better Smiley
« Reply #4 on: January 27, 2014, 03:46:45 PM »
916
996
998
748
848
1x98
M696/796/1100
StreetFighter
MTS620
MTS1X00DS
ALL SS models
None of those fenders will fit my Monster.
« Reply #5 on: January 27, 2014, 06:00:01 PM »
The following fenders WILL fit ALL Monsters Model Year 2000 and after (or those fitted with 2000 and after forks) :
~~~SNIP~~~
ALL SS models 1998 and after
~~~SNIP~~~
Pretty sure that's fixed it.
Enjoying the ride
« Reply #6 on: January 28, 2014, 04:09:31 AM »
Thank you . .  .
I was abke to ask the 796 ownwr abot his front wheel, he said "manhoke with no civer, all my front was damaged, got a used front end from thebay store from a 696 ". . .but, the brakes pads are still the same from what I've been abke to research
freeclimbmtb
From Zero Member to
« Reply #7 on: January 28, 2014, 11:04:27 AM »
Enjoying the ride
« Reply #8 on: January 28, 2014, 11:12:35 AM »
It' clear,  fell into a manhole with no cover, had to replace whore front end with one of a 696 . . .
Skybarney
Fako
« Reply #9 on: January 28, 2014, 11:48:52 AM »
Ouch!  Years ago I was in a carpool lane after dark in SoCal with a CHP following me.  He went around me and back into the carpool lane.  A couple of seconds later his car spun right into the K-rail.  There was a missing drainage grate.  I have never been so grateful for being passed in my life......
rule62
« Reply #10 on: January 28, 2014, 01:05:06 PM »
All your manhoke are belong to us. Someone thebay us up the civer.
Enjoying the ride
« Reply #11 on: January 28, 2014, 01:32:10 PM »
laughingdp
you talk fat-finger too!!!
Enjoying the ride
« Reply #12 on: January 29, 2014, 09:28:48 AM »
laughingdp
