s2r1000 belt change mishap
Started by dholbrook, January 26, 2014, 06:16:15 PM
dholbrook
Hi everyone, I am new to the site and this is my first thread.  It's appropriate because I was attempting my first monster (08 s2r1000) procedure and ran into a problem.  With belts off, I rotated the crank...dumb move.  Nothing was binding or anything like that but now I am wondering how to get my pulleys all back on track.
Is it true that if I align all the pulleys with their marks, and I can see the flywheel tick mark through the hole, that I can put my new belts on?
I assume I need to find TDC of compression stroke on horizontal cylinder for the pulleys to align, but can I find TDC without belts?  My finger feels pressure while over the spark plug hole, but can I be sure of what the valves are doing if there is no belt?
Besides the horror of what might happen if I get it wrong, what's the best way for me to proceed?
Thanks so much and please be patient as I am new to all of this.
Best,
Dean
The pulley marks will only align in the proper place.
If the valves are closed/belts off then pressure from the horizontal cylinder will occur on both the compression and exhaust stroke, but since the pulleys only align on the compression stroke you're good.
When you tension the new belts make sure each cyl is at TDC as the closer assist spring will alter the reading.
dholbrook
So then I'm ok to assemble as long as all the pulleys line up in the end?
Align the marks carefully and assemble.
Rotate the motor by hand with a crank turning tool to double check for any binding before you fire it up.
dholbrook
Maybe I'm over thinking it, I'll put everything in place with belts on and go from there.
Quote from: dholbrook on January 27, 2014, 07:23:28 PM
The results of doing it wrong are indeed a nightmare, but it really isn't rocket science.
You can do it.
Once you get them on do you have a method to tension them properly?
Yep as DP has said, just take your time and you should be fine. Turning the crank with the belts off is a hassle not the end of the world.
And FWIW the vertical cylinders pulley came off the mark as soon ans you took the belt off. With the marks lined up right, the cam is resting on the spring and will turn with the slightest provocation
dholbrook
Thanks for you help!!  I was really thinking that hitting the start button would be like pushing the button for one of those implosion demolitions.  Now I have greater confidence though, thanks to you all. I aligned all the pulleys while the tick was visible in the peek hole.  It turns over without any noise except the rushing air out of the spark plug holes.  I've downloaded a guitar tuner app and will see how well it works tonight.  The belts from CA Cycle Works are recommended to 99 Hz.  If I can't get solid readings, I'll slip a 5mm allen key through, but not enough for a 6, then recheck after it starts, warms, then cools.
Thanks again,
Dean
Quote from: dholbrook on January 28, 2014, 05:16:51 PM
Thanks again,
Dean
The Allen key method does not work on a 1000DS.
rule62
FWIW: The free "G-Strings" tuner app for Android works like a charm. Consistent, repeatable, frequency readings. Used it for the 620 and the 748 with no problems.
SpikeC
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
Quote from: SpikeC on January 29, 2014, 01:42:35 PM
Why not?
The idler/tensioner pulleys are in different locations than the older bikes which changes things.
Once tensioned you could check with an allen and figure out what size to use, but it's not a 5.
SpikeC
 Thanks,I will get in there and check with the tuner app. When I changed the belts I checked them with the allen method before pulling the belts and the horizontal was a tight 5mm, the vert. a tight 4, so I did 5 on each. There were only 3k on them at that time.
Spike Cornelius
  PDX
   1965 T100SC
dholbrook
Thanks for the advice, I had no idea the allen key wouldn't work for the 1000DS.  I'll look for the specific G Strings app for the frequency....  searching "g string" out in the garage... work may get accomplished!
oldndumb
#14
I have no experience with this company. Just offering it in case someone is interested. Or maybe someone could critique their instructions?
http://ducatitoolrental.com/Home_Page.html
