February 25, 2025, 12:31:45 AM *
News: Please Help
Author Topic: Ball Joints for the Suspension Hoop 2001 M600  (Read 1583 times)
Radracer6
« on: January 30, 2014, 08:41:08 AM »
Hi All,
I raised the rear height on my 01 M600 using instructions off ducatisuite. I let out the ball joints as far as I could according to his recommendation. I don't feel like it raised the rear enough. Did they sell replacement ball joints for the hoop that were longer than the stock ones to bring the rear higher??
Online Online
« Reply #1 on: January 30, 2014, 10:27:59 AM »
How much thread did you leave in the hoop?
Radracer6
« Reply #2 on: January 30, 2014, 12:00:32 PM »
~10mm in like he recommended in the writeup
Online Online
« Reply #3 on: January 30, 2014, 03:29:18 PM »
That sounds right, you leave the minimum thread depth equal to the width of the bolt as a rule of thumb.
I remember there were some hoop spacers available, but not sure who sold them. Motowheels has a closeout on an extended billet hoop iirc. Check with the sponsors for those extensions.
Cheers.
brad black
« Reply #4 on: January 31, 2014, 04:41:45 PM »
http://www.ebay.co.uk/itm/LOUIGI-MOTO-DUCATI-RACING-REAR-HOOP-SUSPENSION-JACK-UP-BOLT-851-888-MONSTER-/151217249592?pt=UK_Motorcycle_Parts_13&hash=item2335401d38
the thing with them is that when you increase the distance between frame and swingarm you move the hoop mounting point down, but you also move the lower shock mount down by a bit less than half that distance.  so it's not a straight increase in the hoop extension amount.
also it'll get pretty flighty on the front is you jack the back up.  we used to push the forks all the way down just to settle them down a bit.  check the sag at each end too, you might have unevenness there giving a change in attitude just from you sitting on it.
Brad The Bike Boy
http://www.bikeboy.org
brad black
« Reply #5 on: January 31, 2014, 04:44:07 PM »
more here: http://www.mcmaster.com/#standard-threaded-standoffs/=qhvpzp
Brad The Bike Boy
Radracer6
« Reply #6 on: March 11, 2014, 06:18:06 AM »
"also it'll get pretty flighty on the front is you jack the back up.  we used to push the forks all the way down just to settle them down a bit.  check the sag at each end too, you might have unevenness there giving a change in attitude just from you sitting on it. "
If i install the jack up bolts from Louigi, is it safer to thread the existing bolts all the way in to them (since they're currently only 10mm in the hoop itself)
Rudemouthsky
Autonomous red and black
No gods and no masters
« Reply #7 on: March 11, 2014, 07:02:56 AM »
This is what I used for my 2001 hooped Monster:
« Last Edit: March 11, 2014, 07:28:11 AM by Buck Naked » Logged
Radracer6
« Reply #8 on: March 11, 2014, 08:35:26 AM »
Whoa thats a long extension. The ones from Louisiana moto are 25mm. Did you raise the forks to compensate?
cayman s
« Reply #9 on: March 11, 2014, 08:59:16 AM »
SS threaded rod (subsequently cut to length) and Aurora female heim joints.
Rudemouthsky
« Reply #10 on: March 12, 2014, 04:07:03 AM »
I switched to a taller profile tire at the same time to compensate (from 60 to 70). TBH I preferred the way the bike handled better before, felt more stable. The only reason I used those risers is because my license plate would hit my rear tire before. I may get a set of those 25mm risers Brad posted when I put my bike back together.
memper
« Reply #11 on: March 17, 2014, 08:18:56 AM »
The McMaster standoffs are US, not metric. Boo
