Motogadget loom project
Started by ducatigirl100, February 08, 2014, 01:03:14 PM
ducatigirl100
#15
Quote from: Speedbeaver on February 12, 2014, 06:18:38 AM
Keep up the good work Isa. Looking forward to go riding next summer!
[thumbsup]  [Dolph]
caperix
Looks great, I have been wanting to do something similar myself.  Where did you source the propper connectors from?
ducatigirl100
MAXdB
Just out of curiosity, how do you go about even figuring out where to start and how to do this?!  It seems so impossible.. what sort of background do you need to understand this stuff.. i doubt it's just common sense, or is it??
caperix
ducatigirl100
#20
Quote from: caperix on February 13, 2014, 12:30:42 PM
That looks like a very nice kit, Thanks for the link.  Good luck with your project, be sure to post more pics.
Just make sure to get the wrigth crimping tool....    Deutch connectors hare very hard
ducatigirl100
Quote from: MAXdB on February 13, 2014, 11:22:34 AM
WARNING !   If you dont know how to use a multimeter .... forget this project playing whit electrical stuff can be letal
1-having experience in soldering electronics is critical
2-A good knowledge about apms,volts, ohms, grouds etc... is necessairy
3-understanding AWG gages and how they interact whit the connectors and how to crimp properly..... very importat
3.2 - Be preprapare to do the imposible and alot of patience! :D
4-  + have been playing in the loom for a couple of years ;D
Quote from: JohnEE on February 09, 2014, 05:10:00 PM
I need to buy an extra loom to play around with... good luck ducati girl
Hmm, I picked up an extra for my 900 a while back... hmmm. Ditching the big fuse box and some of the other obnoxious wiring would be nice.
Keep up with the details ducatigirl100! Very neat
ducatigirl100
#23
Update  [popcorn]
1-tail section
2- sensors ( oil, neutral, rear brake)
3- ingnition section ( i've used the old conectores form the coil and ignition module )
4- front section ( horn, signal, headligth )
5-motorscope tiny [drool]
A few principle of desing
1- dont run ground in the loom because it make it bigger....
2-Ground  at the "base's"   at front, midle and rear sections
3- using pods ... i'll use part of the aibox to put electronics in it making it very clean
Very cool, keep up the good work!  [clap]
For a moment, I thought you drew those numbers on the floor!  :-X
ducatigirl100
Quote from: Speeddog on February 24, 2014, 05:08:59 PM
I actually did ... I'm blonde ;D lol
ducatigirl100
#26
the motogaget motorscope tiny is .... well... tiny  :o
0.5 mm gauge ( I think... ) !!!! :o almost impossible to crimp  properly  so some soldering is needed to make a good connection...
DucHead
Wow, impressive work!
By any chance, do you have a less-attractive, older sister?   ;D
brad black
chicks and their wiring looms eh.
what's the weight saving?
Brad The Bike Boy
http://www.bikeboy.org
ducatigirl100
#29
Quote from: brad black on February 27, 2014, 01:46:34 AM
Total weight lost is about 15 pounds ...  [bow_down]
