Re: S4RS RIZOMA REARSETS MOVEMENT
Started by Fudge, February 21, 2014, 03:51:50 AM
Fudge
Ive fitted rizoma rearsets to my 08 s4rs.
There seems to be a bit of movement of both pegs (more on brake side) at the swing arm pivot bolt mount.
All bolts have been torqued up to specs but pegs are still moving.
Im a little concerned as I believe pegs should be rock solid.
Has anyone else fitted rizoma rearsets and have the same issue or am I worrying about nothing?
Thankyou all in advance.
Sundog
I have Rizoma rearsets on my m1100, there is no play at all, tight as a drum. Something ain't right, missing a spacer maybe or washer? dunno sorry mate, but there shouldn't be movement.
M1100 2010 in Ducati Titanium Grey
Custom Wizard Sleeve pipes & PC5 with O2 opt
14T Front
DP Anodized Pressure Plate DP Tail Chop
DP LED Indicators               Rizoma Rearset & Mirrors
Oggie Sliders                     Rizoma Bars & Levers
StephenC
^^ What he said.  Mine are solid, though I recall the spacers being different on the brake and gear sides.  Where is it loose?  Where the rear set mounts to the bike or where the pegs mount to the rear set?
Ducati Monster 1100S (2009)
Two dogs
Hi Fudge
Paul and I saw you at Eastern creek during the week.  [thumbsup]
Drop in more often for a chat.
Fudge
Was good to meet some fellow monster enthusiasts at EC two dogs and Paul. Will have to orgynise a r8de with you soon.
I sent a short video to rizoma and they sent me a modification kit which had some extra spacers and a fat foam washer. Fitted it as there new modified instructions and presto, no more movement!
Although, last track day i managed to grind a bit off the toe piece on brake lever. Not happy but impressed. Time to start playing with adjustment.
Back at the track marshalling and riding on 15th June.
