November 23, 2024, 09:45:26 AM *
News: Please Help
Author Topic: bummed  (Read 953 times)
bdfinally
« on: March 08, 2014, 08:55:26 AM »
Replaced a burned out ignition switch connector & rectifier back in November. The battery I had at the time would not take a charge on my Battery Tender, so bought a new one for this riding season. Got a couple of nice days to ride to work a few weeks ago and everything worked fine. Last weekend tried to start it and battery didn't have enough juice to start it and just wound down, so charged it last night , got a solid green light on the tender, slipped it in and hit the button and get nothing but a constant clicking. Instrument panel lights and headlight come on. Solenoid gone now? Bike is '00 M750 w/39K.
As always, thanks in advance.
« Last Edit: March 08, 2014, 08:59:39 AM by bdfinally » Logged
« Reply #1 on: March 08, 2014, 09:08:55 AM »
If you have a voltmeter, I'd use susyj's post to check all your connections via the voltage drop method.
http://www.ducatimonsterforum.org/index.php?topic=39905.msg711729#msg711729
or howie's video...
http://www.ducatimonsterforum.org/index.php?topic=63462.0
« Reply #2 on: March 08, 2014, 09:52:34 AM »
First I would start with fully charge  the battery if below 12.6 volts and load test the battery...ummm...just noticed, '00, if the battery is not sealed check the electrolite level.  If the plates are exposed  add enough water to cover the plates.  Then go to voltage drop.
bdfinally
« Reply #3 on: March 09, 2014, 07:43:58 AM »
charged it up to 12.65 V and took it to advance for a check. Their check says it failed, had not enough cranking amps. Guy asked me if it had "frozen" when he looked at the cells. Is that really an issue? The bike sits outside and it's been a uber cold winter in stretches but most of that time it was covered and the battery was out of it. Anyway bought a new battery it's on the charger and I'll do the suggested test when it's up to stuff and report back. Thanks for the suggestions, DP & Howie
« Reply #4 on: March 09, 2014, 07:54:19 AM »
A weak or dead battery will freeze.  The acid sort of works like antifreeze As specific gravity drops freezing point raises.  Did this happen to you?  Dunno.
bdfinally
« Reply #5 on: March 09, 2014, 08:22:42 AM »
I think the battery is just a symptom. It's only been in use since January, probably stayed in the bike 10-14 days and only 3 or 4 without use. When I replaced the rectifier/regulator I didn't have a chance to replace female connector that has some corrosion. Possible problem there in the charging system?
SpikeC
Spike in PDX
« Reply #6 on: March 09, 2014, 10:46:41 AM »
Corrosion is an excellent insulator!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
« Reply #7 on: March 09, 2014, 05:57:13 PM »
Yep.  Fix that connection.  That is the weakest link in the charging system.
