Extreme practice
Started by Monsterlover, March 14, 2014, 05:52:51 AM
I doubt it matters. If your comfortable doing it, do it.
Kopfjager
Quote from: NAKID on March 11, 2015, 12:30:57 PM
With as much stop and go traffic I see on my daily commute, and the traffic that goes from 70-0 instantly, I've gotten used to not only braking hard but downshifting as well. I don't just pull in the clutch and drop several gears, I clutch in, downshift, engage, clutch in, downshift, engage, etc.
Is that bad?
I've driven that way my whole life. On occasion I might 'coast' brake, but rarely.
Quote from: kopfjäger on March 14, 2015, 06:36:32 PM
OK, glad to see I'm not the only one. Seems to slow down much faster this way rather than just braking. Also means I'll be in the proper gear if I have to get right back on the throttle to avoid something else...
SwiftTone
When braking hard, get on all fours...front and rear brakes, clutch and shift. I think your in a emergency braking situation, the next gear you need is 1st
Kopfjager
I never use rear brake on the street, never.
Quote from: kopfjäger on April 25, 2015, 05:31:34 PM
I pretty much don't either.
Maybe if I'm at a stop on a really steep hill I'll cheat and use it to hold the bike in place when I go to get moving again.
Kopfjager
Quote from: Monsterlover on April 25, 2015, 07:40:32 PM
Agreed
herm
Quote from: kopfjäger on April 25, 2015, 07:46:15 PM
Agreed
another agreed.
I was just reading an article on Cycle World on this very subject (extreme braking).
manwithgun
One thing to keep in mind about extreme braking, whether it's a panic situation or just going deep, is to never "snatch" at the brake.  It needs to be applied while being mindful of how much load has been distributed into the tire.  A front tire can be rather easy to lock up if you are just riding along and quickly pull at the lever.   The weight and inertia of the motorcycle has not had a chance to transfer through the suspension and downward into the contact patch where it compounds your grip level.   In a straight line, on any halfway descent surface, a properly loaded tire would more than likely throw you over the bars before it skids (cruisers and harleys excluded).  We're only talking about a fraction of second here, but it is a crucial moment in time...
I ride both kinds,   Country, and Western.....
MONTY59
the advice you guys are giving is priceless.the brakes on my 1993 monster are far superior to any other bike i've owned and to be honest i'm sh-t scared to jam the front brake on in case i go over the bars. and i've been riding for 30 years [Dolph]. I will endevour to practice [beer]
You won't just for over the front.
Likely you would lock the front or brake so hard the rear came up a little. Or a lot ;)
Start easy and work your way up as you become more comfortable.
Honestly, 20 minutes in a parking lot may double your knowledge of you front brakes capability.
MONTY59
 [beer]monsterlover will practice  [Dolph]
