Sumfink wrong
Started by Sabre Brian, April 24, 2014, 06:02:56 PM
Sabre Brian
I hadn't ridden my 08 S4RS for about a month.  Went to hop on the other day and the battery was flat.
Tried to get it going with a jump battery.  It started, but then as I was driving out the driveway, it stalled.
Bit the bullet and bought a new battery, but now the bike wont turn over.  It is like there is not enough
power to crank it.  It's like it is trying to turn the motor but nothing there.  There are tons of volts in the
battery.  Could it be the starter motor or something?  Would like to know if there is a simple thing I am
missing before I run off to the expensive bloody mechanics.
Thanks in advance.
I'd check for corroded connections on battery, starter, earth wires to the frame, starter switch, any ECU earth wires, fuses, etc. Some people have tested by bypassing straight to the starter with a battery (+ on + earth to starter case).
If there is a computer problem you will need help, but check out the other stuff first. You could pm Brad or post in Tech if the more obvious stuff doesn't show up the problem.
monstermick58
Go with what Koko64 said and when you are checking your wires also check that the connectors haven't corroded where the wire goes into the connector as this will create lots of resistance
                                    Mmick
Sabre Brian
All the wiring seems good.  No signs of corrosion or anything like that.  Checked all the fuses and they are good.  Buggered if I know.
Off to mechanic I guess.
Betty
Quote from: Sabre Brian on April 25, 2014, 03:09:46 PM
Keep in mind that I don't know what I am talking about (I am sure somebody can elaborate if I cause confusion) ... but did you also check the big fuse near the battery/ECU (ie. not with the other fuses).
monstermick58
Quote from: Betty on April 25, 2014, 09:15:59 PM
He seems to have power just not enough Betty, if the main fuse was blown you would not have any power at all and you would see that at the dash.
                                   Mmick
Betty
Quote from: monstermick58 on April 26, 2014, 03:29:28 AM
                                   Mmick
Okey dokey ... just thought if he was checking fuses that one might be missed, because it doesn't hang out with the other fuses.
Sabre Brian
I was looking at the bike last night and I went to pull the clutch in and I could only get it in half way.  Could my dry clutch be seized or something?
Sabre Brian
OK so a bit more investigation.  I put a test light on the battery side of the solenoid and there is power, but on the positive terminal of the starter motor,
there is no power when I hit the starter.  Rooted solenoid maybe?
suzyj
Grab an 11mm open ended spanner and short the two big terminals together with this. If the solenoid is dodgy this will start the bike.
I carried an 11mm spanner around for about a year before I got around to fixing the underlying issues.
J5
you need to charge new batteries before use
it wont be at full capacity and from experience if the battery isnt near 100%
then it wont kick over
Sabre Brian
I will try the charging thing tonight.  If not, I think it is time to just bite the bullet and head for a mechanic.  Thank you for your help guys
monstermick58
Try what SuzyJ said (Hi Suzyj) I can see where she is coming from, like she said it will tell you if the solenoid is not working, with your clutch is the bike in neutral?
                               Mmick
Sabre Brian
Mick it was.  I took the cover off and put a bit of WD40 on the shaft and it freed up.  I was reluctant to use spray on it, but by that time I was thinking I was up for a new clutch anyway.  It seems ok now.  I don't think the solenoid is to blame anymore.  The starter is trying to work.  The charge thing is the last thing I will try before sending to the shop.
I have another bike which is getting all my attention at the moment, so the Monster is on the back burner currently, although it kills me every day I know it isn't running.
Sabre Brian
If it wasn't for bad luck, I wouldn't have any luck at all.
So the result.  The battery was fine apparently.
I bought a new battery, drove straight from the shop to my home, and it would not crank over my bike,  I assume that it being a new battery,
there must be something wrong with the bike.  Then of all things, the clutch seems to lock up.  I remove the clutch but can't get the pressure plate free, so I try to get some CRC down into the shaft without getting any on the plates.  Got the clutch free, but still no start.  Start looking at this that and the other electrical problem, and someone on here (J5) says the battery probably isn't fully charged from new.  So I put a multimeter on it and it says 10.85 volts.  Bugger.  My old charger is stuffed so I go and buy a brand new battery charger.  Charge it for 24 hours.  Still 10.85 volts.  Motherf%#$%#er.  Back to Battery World, who tell me that they need to charge the battery and then test it tomorrow.  By this time I am more than a little miffed and give the staff at Battery World more than a hard time about having to make a 3rd trip back to their shop for my battery.  They ring me back the next day and tell me the battery now has 13.1 volts and is fine.  I go and pick it up and take it home.  Bike starts perfectly.  I decide to take it for a long overdue cane over to a mate's place, and now the friggin clutch is slipping like shit, no doubt thanks to the CRC.  Perhaps I should just ride a furgin moped.
