Some updates
Started by hackers2r, May 16, 2014, 11:41:15 AM
hackers2r
I recently completed a few upgrades that took WAYYYYYY longer than expected:
New exhaust, dry clutch conversion, ducshop hyper stacks, and 900ie cams with a custom tune.  Bike made 84hp after being tuned.
Just thought I'd share the updates.
thorn14
M620 turned M800 but then back to M620 after the M800 died at 110k, and now to Multi 1000.
hackers2r
Yeah...S2R 800.  Used the 848 dry slipper conversion kit.  Biggest issue was their special nut.  I had that machined to fit the shaft and apparently it wasn't strong enough and broke off.  Then had the clutch hub machined and a new nut made which was quite the process.  After that, it all went to together pretty straight forward.  Let me know if there is anything specific you're interested in.
thorn14
Were the 900ie cams drop in compared to the carbie cams or did you need the spacer? Did you get any other headwork done?
hackers2r
The cams did require a spacer but that was very easy to make.  No other headwork done.
