How to reset tps on 2012 monster 1100
Started by Radracer6, May 17, 2014, 05:16:47 PM
Radracer6
Hi I've installed a reflashed ecu and want to reset the tps. I've read to cycle the ignition 3 times to reset. So this means turn the key to on the. Off three times and in the forth fire it up? Will there be any readout it was reset?
Yup . . . or, go to dealer and have him do a full system diagnostic and then they can do a "Reset" . . .
oldndumb
Quote from: Darkmonster620 on May 17, 2014, 05:18:39 PM
Scratch the "Yup" for a "Nope", then the rest is correct. The evo ecu does not respond to the ignition 3 times reset trigger. It actually does a reset at each power on. But for peace of mind, a quick verification with your shop should be cheap.
Quote from: oldndumb on May 18, 2014, 09:29:09 AM
My apologies, what you wrote is what I wanted to state . . . trying to answer to different people at the same time can confuse things . .  Thanks for the correction
oldndumb
No apologies needed. My turn to err is coming up next.  :)
