M1100 high/low beam out* Updated, problem fixed! *
Started by danaid, May 23, 2014, 10:49:20 PM
danaid
The dash shows the blue high beam indicator is on, toggling the high beam switch does nothing. Turn signals and brake light works fine. What should I look at first?
Thanks in advance,
Dan
11' 1198SP  Black
09' 1100S    Red
Harness to the headlight bulb.
danaid
I was thinking that, hopefully that simple. I've had the dash/light assembly pulled off its support pegs to access to the fork tubes recently. I'll check the harness for tightness.
Thanks!
11' 1198SP  Black
09' 1100S    Red
danaid
So I found the culprit, the single connecter pin is burnt. I can wiggle the connection when connected and the lights will work.
So how do I fix this and most importantly how did happen and can what can prevent his from happening again?
11' 1198SP  Black
09' 1100S    Red
danaid
11' 1198SP  Black
09' 1100S    Red
Quote from: danaid on May 24, 2014, 10:00:33 PM
http://www.easternbeaver.com/Main/Elec__Products/Connectors/Sealed/SM-HM/sm-hm.html
Is the 4 position connecter on this page what I need ?
Looks about right, but no FHE.
I'd E-mail him about an alternative higher-current capability connector before buying the same thing as what just burned up.
danaid
Finally switched out the stock, burnt connecter with a higher quality, higher amp rated connecter. I was nervous about tackling the job as I usually stay away from electrical jobs.
I found this place on line, http://www.cycleterminal.com/index.html
I sent pics of the stock, burnt connecter to the owner of cycle terminal and he quickly replied back to me with confirmation of the stock part name, and all the specks, and helped with selecting upgraded parts.  :)
11' 1198SP  Black
09' 1100S    Red
