December 26, 2024, 07:50:01 AM
Track/hack job
Topic: Track/hack job (Read 2195 times)
HotIce
Track/hack job
May 25, 2014, 06:51:35 AM »
So I finally received my 2012 1199 with Termis and 4000 miles. Bike sounds basically new, from a mechanical and looks POV.
But, she has seen some track, I guess, from tape on wheel weights and some "hack", more than "track", jobs.
I believe the mess in the heat exchanger bolts is silicone to prevent them getting off.
Nevertheless, it looks like $hit
Have anyone seen such wacko use of silicone to keep bolts from getting out?
There is more. Since the Pani oil filter cover can be a *itch to get off, and since the previous owner seemed to be in love with silicone, he stuck a screw on it, so you can pull it back directly, w/out having to pry it out with picks.
While I admire his inventiveness, I puke on the end result.
Re: Track/hack job
May 25, 2014, 07:04:41 AM »
You might get some better answers in tech
Enjoying the ride
Re: Track/hack job
May 25, 2014, 07:08:42 AM »
NO words for such fine artwork
Have you started the bike? Does it leak oil? You say it sounds "new" Have you riden her? If yes, how does she feel?
I know "we" are to use black silicone only, Threebond brand preferably, but, this might be hiding something . . .
HotIce
Re: Track/hack job
May 25, 2014, 07:18:32 AM »
Ne leaks AFAICS.
I have ridden her some yesterday, and it felt perfect. Will ride much more today.
BTW, the ones who say that the 1199 is a PITA to ride in traffic, have never ridden a 748 or a 1098
Also, leaks, would call for a different placement of silicone, instead of just wrapping bolts.
I might replace the oil filter cover, if that turns out to deprive my sleep at night.
Wonder how to get rid of the silicone red mess in the heat exchanger, if I wanted to ...
BTW, for some people, should not be allowed to work on their bikes
Enjoying the ride
Re: Track/hack job
May 25, 2014, 07:26:03 AM »
Quote from: HotIce on May 25, 2014, 07:18:32 AM
Ne leaks AFAICS.
OK, good to know NO leaks . . .
Spray with Brake/Parts Cleaner and using a "clock worker" or precision screwdriver try to pry it, slowly, that's how I do it . . . Another method I use, if silicone is way too stubborn, I will damp it with some gasoline . . .
Triple J
Re: Track/hack job
May 26, 2014, 09:37:31 PM »
RTV (the red silicone) is commonly used to keep certain bolts (like chain adjustment bolts on a DSS) from backing out...or to mark bolts so you can visually see if they've backed out. I've never seen them completely covered like that though!
I'd just clean it off and move on if everything else seems fine. People do strange things to motos sometimes.
HotIce
Re: Track/hack job
May 26, 2014, 09:44:17 PM »
Any suggestion on how to get it off w/out doing an ever bigger mess?
Re: Track/hack job
May 27, 2014, 08:40:23 AM »
I suspect that bolt is threaded into the oil filter cover, hopefully with a locknut on it.
But the RTV there would be so it doesn't leak (as much).
Don't mess with that one unless it starts to leak, or you're ready to do an oil and filter change and have a new cover in hand.
HotIce
Re: Track/hack job
May 27, 2014, 08:44:43 AM »
I already got a new oil filter cover enroute, and next oil change will replace the hack.
On the positive news. Oh Lee Fuk! That is freaky fast!
