swingarm compatibility
Started by MotoPsycho, May 28, 2014, 12:15:48 AM
MotoPsycho
I know I saw it somewhere here but evidently I'm searching for the wrong thing. Somewhere I saw a Gen 1 Monster with a Supersport swingarm on it. I remember seeing one of Doug Cook's pictures that made it work but the entire back of the frame looked like it was missing. Obviously I'd need a SS swingarm, shock and mount for the head. But...
Who's done it and made it work ? What had to be cut out to make it fit ?
If I can ditch my hoop and linkage to clean everything up and open up a new possibility for rear suspension I'm all for it.
MotoPsycho
I saw pictures of one of his builds but that still doesn't answer my questions.
Assuming axle size is the same (17mm) I believe a mid 90's one will work. Correct ? What about pivot size ? Is that the same ?
Düb Lüv
Pretty sure all supersports have 17mm axles and same pivot/diameters as DSS monsters.
Building, building, building
Quote from: Düb Lüv on May 29, 2014, 07:35:03 PM
AFAIK, ^^^ is the case.
Aesthetically, the last SS swingarm is the one to get.
Fitment wise, I think they're all the same.
Stu added an upper shock mount to the frame, and re-configured the bottom of the tank (not a day's work).
I think Dub Luv got an upper shock mount that goes in place of the rear vertical valve cover, but it's on a DS engine.
Dunno what else would have to be modded on a Gen 1, oil breather tank and fusebox/electricals?
MotoPsycho
Quote from: Speeddog on May 29, 2014, 09:58:02 PM
Thanks SD and Dub, that's what I needed to know. Now to look for the valve cover shock mount. Or, I have a friend that's an excellent fabricator and I'm sure I could persuade him to lend a hand. Oil breather tank is gone and the wiring will be redone/cleaned up before I get that far. I'm just trying to think ahead of the game. That way I won't have to worry too much when it comes to 3-4 week shipping times.
My preference would be to add a shock mount to the frame.
A bit of clever design and it could be a bolt-in.
The DS have a nice spigot in the head to feed the load into.
Earlier motors do not.
Either way, I'm a bit leery of feeding that load into the head.
Perhaps it's OK, but the cylinders and heads weren't intended to be structural.
MotoPsycho
Yes, agreed. Thanks again for the help fellas.
