Samco or DP Hose Kit - Pics?
Started by arai_speed, July 10, 2008, 12:05:28 PM
arai_speed
Hey everyone, does anyone have pics or first hand experience with either the Samco or DP hose kit as displayed in the following picture:
I've been considering this silly mod on my bike but would like to see some Monsters with it.
Any of you have pro's/con's on such a mod?
Thanks.
MonsterMan1036
Here's some pics.
Not really silly, looks a ton better and the hoses will last a lot longer. The hoses are easy to install and should only take an hour max to put on. I would recommend getting all new high quality hose clamps to replace the stockers.
Alex Ortner 1036CS
1036 Foggy Monster (sold)
Commonwealth 848 track bike
1199 Tri
arai_speed
Quote from: MonsterMan1036 on July 10, 2008, 12:56:36 PM
Here's some pics.
WOW! That looks great!  The hose kit does not come w/new clamps?  If it does not, which clamps did you use?
arai_speed
Also, is there any sort of prep work that needs to be done before removing the stock and installing the new ones?
Thanks.
MonsterMan1036
#4
Hose kit:
http://www.motowheels.com/italian/myProducts.cfm?parentcategoryid=8%7CEngine&productID=4869&showDetail=1&categoryID=16
Clamps:
dam link will not work, there on the bottom of the page in the link above
Quote from: arai_speed on July 10, 2008, 01:22:34 PM
Thanks.
No prep work other than draining the coolant. The easiest way to drain is to pull the largest hose and let it drain into a bucket. Then just replace the hoses one at a time.
Alex Ortner 1036CS
1199 Tri
arai_speed
Quote from: MonsterMan1036 on July 10, 2008, 02:42:07 PM
Hose kit:
Clamps:
thanks man!  I took a look and they only have the blue ones :(  I'll look around for the red set online.
Capo
Where did you get that shift lever?
Capo de tuti capi
moto
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
MonsterMan1036
^^^That's the one, I also had a longer peg made for it and it's on in the pic.
Alex Ortner 1036CS
1199 Tri
