August 06, 2024, 07:21:04 PM
Will I Ever Get This on the Road?
5
Topic: Will I Ever Get This on the Road? (Read 28910 times)
Bill in OKC
S4Rs
Re: Will I Ever Get This on the Road?
Reply #15 on:
July 11, 2014, 07:36:38 AM »
This is a pretty good forum.
http://www.suzuki2strokes.com/forum/
'07 S4Rs '02 RSVR '75 GT550 '13 FXSB '74 H1E '71 CB750
Reply #16 on:
July 11, 2014, 09:28:11 AM »
On the old Yamahas we'd run the pump with the cable disconnected and a premix.
It eliminates the lack of lubrication on decel and also any guess work on the pump cable adjustment.
It does assume a working pump.
Reply #17 on:
July 11, 2014, 10:20:48 AM »
I've been contemplating doing that, but the only thing is if I want to run this around as a commuter, it would be better with a working pump so if absolutely necessary I could fill on pump gas. That is really the only reason I even want the pump.
JM
Reply #18 on:
July 11, 2014, 11:57:16 AM »
Ive got the carb done, and everything fuel-wise back together. Hit a snag though, my petcock is leaking, and the screws (you know, those really soft ones they use) have the heads stripped enough that I can't tighten for a proper seal. Anyone know where to find tiny, metric fine threaded screws? I've already been to the local hardware places with no luck.
JM
Reply #19 on:
July 11, 2014, 03:11:04 PM »
Fastenal?
stonemaster
Reply #20 on:
July 11, 2014, 03:46:19 PM »
you might either JB weld it or cut a slot for a flat head, I've have had both methods work
Reply #21 on:
July 11, 2014, 08:01:13 PM »
Quote from: ducpainter on July 11, 2014, 03:11:04 PM
Fastenal?
I'll look into them, we've got one close by.
In other news, even after the leak issue, for shits and giggles, I kicked it over three times, and it
ning, ninged
to life!
Progress. Leak, then electrics.
JM
Reply #22 on:
July 12, 2014, 06:23:35 AM »
McMaster Carr, if Fastenal can't help.
Reply #23 on:
July 12, 2014, 08:53:27 AM »
I don't have a McMaster locally. Fastenal was no help. Local bike dealer was no help. Probably didn't help that the bike was twice the age of the guy I showed what I needed...
JM
Ducatamount
Reply #24 on:
July 12, 2014, 09:16:44 AM »
A kindly machinist?
half fast
stonemaster
Reply #25 on:
July 12, 2014, 10:29:54 AM »
Quote from: Ducatamount on July 12, 2014, 09:16:44 AM
A kindly machinist?
yea have em made for ya, had to do that a couple of times as well
Reply #26 on:
July 12, 2014, 11:37:23 AM »
Not much industry here, I can't even find a machinist locally. I can however get a complete petcock replacement off of eBay for $20. I may just do that.
JM
Reply #27 on:
July 12, 2014, 12:24:13 PM »
What size screw do you need?
oldndumb
Reply #28 on:
July 12, 2014, 12:28:58 PM »
Quote from: the_Journeyman on July 11, 2014, 11:57:16 AM
JM
I've had good luck and fast service from
http://mdmetric.com
They encourage you to call and discuss what you are looking for and will even help with very small orders.
My local fastenal store is a waste of time. It seems to be is oriented to the commercial and building trades.
Edit: Speeddog posted while I was typing. Odds are he can help you faster.
Last Edit: July 12, 2014, 12:30:48 PM by oldndumb
Reply #29 on:
July 12, 2014, 12:43:57 PM »
Quote from: Speeddog on July 12, 2014, 12:24:13 PM
If the Zook is anything like Honda it's most likely a 5x.08...dunno how long.
5
