January 10, 2025, 07:54:59 AM
Please Help
No Red Key & My Black Key is getting Worn - what to do?
Topic: No Red Key & My Black Key is getting Worn - what to do? (Read 3897 times)
The ModFather
Duck Off
Monster Magnet
August 13, 2014, 04:52:53 PM »
I've got a 2005 Monster 620 Dark that I purchased used about 4 years ago. It did not come with the Red Key (back then I didnt even know there was a Red Key). Now my Black Key is getting worn out in that I've had trouble getting it fully seated so I can turn it. I'm worried I might be a limited number of key turns away from not being able to start my bike.
What are my options here? I'm thinking it might be as follows:
Get the ECU Flashed to disable the immobilizer - (at least $250 I know of two places but I'd have to ship the ECU there) ... then..pick up a blank key on ebay and get it cut to match my current key. (no idea how much this would cost or where I'd get this done).
Is this a viable approach? Does anyone have a better or more cost effective approach? Any caveats I should be aware of? I'm in the Chicago area.
Any advice here would be greatly appreciated.
Thanks
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
Enjoying the ride
Re: No Red Key & My Black Key is getting Worn - what to do?
August 13, 2014, 06:08:36 PM »
Quote from: Duck Off on August 13, 2014, 04:52:53 PM
Thanks
you could have the IMMO deleted and then use any dash/key you wanted to use . . . From what I've read, remember I am at least 3K miles away, some sort of protection would be good . .. Lemme do some diggin to see what can be done in your situation
August 13, 2014, 06:15:10 PM »
Start drinking. Heavily.
For reals, tho.
August 13, 2014, 09:39:39 PM »
You could get your black key cloned. If I remember you are in Chicago?
http://www.omegalocksmith.com/ducati-motorcycle-keys/
Keep in mind, you are copying a worn key and you will still not posses a red key. IMO, the money would be better spent on a reflash.
The ModFather
Duck Off
Monster Magnet
August 14, 2014, 06:17:52 AM »
I thought to use any other key (that wasnt cloned using the Red Key) I'd have to have a reflash to disable the Immobilizer. No?
2008 848 Track Bike
August 14, 2014, 06:19:16 AM »
There are services available to clone a black key without the red key.
Follow howie's link.
Enjoying the ride
August 14, 2014, 07:49:13 AM »
there is also a company in seattle I think . . would have to look it up
Bill in OKC
S4Rs
August 14, 2014, 08:54:31 AM »
I had a black key cloned by a local shop. He used his machine for cars but when he looked in the manual, it said it worked for Ducati too. I had to buy an aftermarket key with a transponder chip off of ebay to do it. The key was about $40 and cloning was about $20 I think. I also gave my red key a go and he was able to clone that too - it had all the functions of the red key but it was aftermarket black.
Last Edit: August 14, 2014, 08:59:47 AM by Bill in OKC
'07 S4Rs '02 RSVR '75 GT550 '13 FXSB '74 H1E '71 CB750
jduke
August 14, 2014, 11:34:53 AM »
For about $250, Bobby at Houston Superbike can reflash the ECU and disable the immobilizer. Might even have a DP Race map he could load on it.
The ModFather
Duck Off
Monster Magnet
August 14, 2014, 12:43:56 PM »
Quote from: howie on August 13, 2014, 09:39:39 PM
Just trying to understand the last part of this statement. Why would the money be better spent on a reflash?
2008 848 Track Bike
Enjoying the ride
August 14, 2014, 03:43:06 PM »
Quote from: Duck Off on August 14, 2014, 12:43:56 PM
between the cost of the blank, the cutting, the cloning, dunno, but, could be close to $250 . .. and really, you could enjoy the 618cc engine a bit more with the DP map
August 14, 2014, 03:46:56 PM »
Quote from: The Last In Line on August 14, 2014, 03:43:06 PM
Plus...
when
your cluster dies you can put any gauges on the bike.
rnicholson
August 14, 2014, 04:59:05 PM »
I recall stumbling on this guys suggestions on what to do without a red key a few months ago --
http://ducatikeys.runfrom.us/:
Quote
Give it the glue. Glue one of your working black key's to your bike's frame (near the ECU) and you'll be able to make "dumb" copies of your key now, since the radio signal from your black key will always be close enough to be read by your ECU you don't need to worry about makind special keys any longer.
Just be certain that you A) make copies of your black key first and B) be certain your ECU can read your black key from it's mounting point. BEFORE glueing your key to your frame
Not saying its sage-like advice, but it does seem to be a low cost solution to the problem -- Just the cost of compatible key blank and cutting a new black key. Although I would be concerned with this approach if my bike was often parked on the street...
2007 S2R 800
The ModFather
Duck Off
Monster Magnet
August 14, 2014, 06:59:21 PM »
That glue trick is actually pretty clever! Lots of good advice here. Thanks so much. Since Im in Chicago I called the guy Howie posted & he's going to clone my black key tomorrow (including rfid) for $75 & that includes the cost of the key!!
I do still want to get my immobilizer disabled though as Ive got some scratches on my gauges & Id like to replace them with white face ducati gauges. But $250 to reflash is steep as thats on top of the cost of gauges. Ive been told that changing my mapping wouldnt be worth it for a 620. Ive got Boom Tubes & I havent opened up my air box at all. She runs great now so Im nervous about changing the mapping as i know theres not one specific to my exhaust. If it were easily reversible Id consider it to see.
Any advice on the mapping here would be great.
Thanks again.
2008 848 Track Bike
J5
I'm here to fix zee fridge
Reply #14 on:
August 15, 2014, 12:48:56 AM »
if your key is worn out and you cut a new one from that you will just have a copy of a worn out key
my first step would be use a little graphite powder to lubricate the lock , put the graphite on the key rather
than filling the lock with graphite
