October 11, 2024, 07:10:32 PM *
Author Topic: Searching for part#  (Read 1465 times)
CMDRDAVE
'01 Yellow M900i.e. '98 Yellow 748
« on: July 11, 2008, 06:10:53 PM »
How do I find a part #?  (front brake light micro switch on 748)  The lists on the ducati web page only go back to 2000.  I need a part for a '98?
Insert witty comment here-->
DarkStaR
« Reply #1 on: July 11, 2008, 06:17:03 PM »
Have you tried calling a Ducati dealer?
CMDRDAVE
« Reply #2 on: July 11, 2008, 06:21:31 PM »
nope, they aren't open until tomorow.   Wink  I am kind of impatient.
« Reply #3 on: July 11, 2008, 06:37:17 PM »
Why do you need it?
I assume the front brake lever wont turn the light on since you recently replaced/fiddled with the lever and the little nub came out?
clubhousemotorsports
« Reply #4 on: July 11, 2008, 08:00:22 PM »
Here you go.          539.4.021.1A
the part number may update but it should be the early style with the attached wires and the small puck actuator
retail is around $43.99
CMDRDAVE
« Reply #5 on: July 13, 2008, 05:33:38 PM »
Why do you need it?
I have not replaced fiddled with the lever, but someone may have at some point.  I did notice that the little rubber "boot"  was not on the actuator portion of the switch.  Is this a common problem.  I found a replacement of a newer 748 but it didn't fit.  Mine mounts with 2 little screws.  This one had press in tabs that don't align with the holes.  I have decided to quit playing around and go with OEM.
DUCVET - Thanks for the #.  Where did you find it so that I don't have to post again for the next little part that breaks?
« Reply #6 on: July 13, 2008, 05:41:56 PM »
I had just ordered one for a customer.
Try looking up part numbers from the parts fiche at ducati's web site.
