October 12, 2024, 03:12:09 AM
Cone Rubber seal in tank came loose. Problem?
Topic: Cone Rubber seal in tank came loose. Problem? (Read 929 times)
venomousr1993
Snapping Like a Squirrel
July 12, 2008, 06:10:41 AM »
Was at the gas station filling up the bike when I noticed a bleck rubber seal tossing about in the tank. I carefully pulled it out and it is shaped like a cone. It seems like it goes at the bottom of the fill tube to prevent splashback. I tried putting it back on with very little luck. I rode home with no problems, leaks ect. Is this a big issue or is this little part totally necessary?
Thanks
WERA Expert #163
Leo Vince
http://www.leovinceusa.com/
Lucas Oil
http://www.lucasoil.com/
WoundedWear
http://www.woundedwear.org/
AXO
http://www.axo.com/us/
EEL
Re: Cone Rubber seal in tank came loose. Problem?
July 12, 2008, 06:33:30 AM »
THROW IT AWAY before it falls into your tank and gets jammed somewhere where you cant get to it.
July 12, 2008, 09:09:32 AM »
Consider it the end of a problem. Follow EEL's advice
Rameses
*Your Mom* has a Hypermotard
July 13, 2008, 08:38:44 AM »
It's happened many times, to many people. No big deal.
I'm kinda surprised you were able to get ahold of it and pull it out through the filler hole.
