September 30, 2024, 08:08:39 PM
M620 tacho snd speedo stopped working
Topic: M620 tacho snd speedo stopped working (Read 1534 times)
mr.freezer
September 16, 2014, 01:58:41 AM »
Hi guys.. ma tachometer and speedometer stopped working... when I turn it on it goes 0-260, but it does not show speed and does not count KMs... I found melted wires from sensor, repaired it, but did not help... what else to check??
Enjoying the ride
Re: M620 tacho snd speedo stopped working
September 16, 2014, 04:54:44 PM »
Ok, from what I read, you don't have a speedo . . . No I don't mean a bathing short . . . but, either I am dumb or misunderstand, do you have a working rev counter?
mr.freezer
September 17, 2014, 10:16:10 AM »
rev counter is working.. speedo and the counter of kilometres do not work...
September 17, 2014, 11:30:42 AM »
First, check the fuse. The speed sensor is Hall effect. Key on, spin rear wheel. You should get voltage at terminal 2.
mr.freezer
September 19, 2014, 11:24:30 AM »
howie.. thanks a lot.. it´s not the first time you have helped me... I checked the 5A fuse that is labeled as "SPEED".. it is blown...
... now the last problem... left side of turn signals... something is wrong in dash...
The ModFather
Duck Off
Monster Magnet
May 08, 2016, 04:43:58 PM »
My speedometer and odometer just stopped working. But I cant find the 5 amp fuse for the speed sensor. It's not in my fuse box. Is it different on an '05 620 Dark? The wiring diagram in the Haynes manual says there should be one but I cant find it. Wierd.
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
The ModFather
Duck Off
Monster Magnet
May 08, 2016, 05:05:25 PM »
okay looking at the wiring diagram further it looks like on the Dark Model it's on the same circuit as the Side Stand Switch which does have a 3A fuse in the fuse box
2008 848 Track Bike
