Ecu question
Started by cbcanada, September 16, 2014, 06:31:57 AM
cbcanada
My new ecu after the reflash has 2 stickers on it.. Which is the correct one?
Also there is two unconnected harness behind the ecu. Anyone know what these are for?
http://flic.kr/p/oXMkxw
There isn't a sticker which normally goes onto an ECU after re-flashing (at least not that I've seen).  The 2 stickers in your photo are the original from when the ECU was new from Ducati.  The Ducati Performance ECU's have a different sticker than the 'SB18DZ12' one you have.
I know there is a single, two-wire connector near the ecu which is used for the service scan tool to communicate with the ECU.  I'm not sure of the 2nd one you're mentioning.
cbcanada
Quote from: Duck-Stew on September 16, 2014, 06:58:44 AM
I will take a picture tonight and post
Battery charger is the second one (at least if S2R)
cbcanada
Sometimes Ducati re-purposed ECUs, mine is also like that, has a sticke with tiped numbers above the metallic one . . . mine was from a 999 ended up being a M620
brad black
the top sticker is the ducati software #.  the other is the ecu sticker from marelli.  some flashers don't put a label on saying what it is.  i generally do, but not always, esp if i'm just disabling the immo.  is there another sticker on the other side.
Brad The Bike Boy
http://www.bikeboy.org
