swap options for s2r monster
Started by Ohm3d, September 23, 2014, 08:18:11 AM
Quote from: Ohm3d on August 28, 2015, 03:46:46 PM
I think the s2r800 has 44mm throttle bodies and the m1000 has 38mm. dunno if its really worth swapping em. I was probably just essentially going to do a frame swap and leave all the additional wiring and things with their proper motor.
The s2r has magneti marelli gauge, m1000 doesn't say that so maybe Siemens?
Nope, should be MM. The newer Monsters are Siemens.
