February 23, 2025, 07:56:59 AM
CAM
Snapped throttle cable
Topic: Snapped throttle cable (Read 2740 times)
J-Cee
October 01, 2014, 06:19:26 PM »
So as I sit here stranded I need to ask if anyone has a throttle cable for an older monster they can part with? I'm in the Baltimore area and would love to pick one up tomorrow. Speeds was very helpful (sarcasm). 2000 M750 carbed
'00 Monster 750 Carbed
The Mad King Pepe'
Re: Snapped throttle cable
October 02, 2014, 02:43:09 AM »
Bicycle or dirt bike shops may have repair kits: generic length cable with screw on cap you set at the right spot.
J-Cee
October 02, 2014, 03:26:40 AM »
I'll try that. Thanks
MongoReturns
I'm very busy
October 03, 2014, 03:23:01 PM »
How the heck did you do that? That's probably the one thing I never think of.
2000Monster750Dark: cored pipes, stage2, 43t, f-18, dptach
2007 1098Red: home depot cooler guard, on sale cluch cover, on sale dp dark tall screen, ebay hugger, hand painted clutch spring caps
MongoReturns
I'm very busy
October 03, 2014, 03:24:27 PM »
On the topic, does your 750 seem to be weaping oil out of everywhere except the wheels?
J-Cee
October 03, 2014, 04:10:50 PM »
Repaired the cable end. Soldered a brass lug on it. The only oil leak I had was out of the oil pressure sender. Replaced and no more leaks.
MongoReturns
I'm very busy
October 03, 2014, 06:01:23 PM »
The lug broke?! Ah well, good on you for a cheap fix. How many miles?
J-Cee
October 03, 2014, 06:31:38 PM »
Don't know for sure. My estimate is around 27k. Removed the cables and throttle from the bike disassembled, cleaned, lubed and reassembled on the bench. Started raining. Bah
J-Cee
October 03, 2014, 06:38:22 PM »
This was my temporary fix to get home.
J-Cee
October 03, 2014, 06:39:30 PM »
Permanent fix. Soldered brass end on.
MongoReturns
I'm very busy
October 04, 2014, 10:53:41 AM »
Nice work! I definitely approve of the cost. Yeah I've got 27k on mine too.
J-Cee
October 06, 2014, 06:28:31 AM »
This is the method I used. Worked great! Do NOT get the flux on your skin....hydrochloric acid. Also be careful how far you dip the cable. It will wick up the strands and make it solid. Our throttle cables bend in a circle immediately after the cable stop so that would suck. Tested first on an old bicycle cable with a spare brass cable stop.
