S2r 1k forks on s2r 800 advice
Started by cbcanada, October 25, 2014, 09:49:01 PM
brad black
Quote from: cbcanada on October 27, 2014, 09:17:29 PM
But does the hole in cartridge not play a function? What is it there for and what will
I lose if I close it up?
the hole in the side of the original cartridge is a compression bleed, which effectively removes the compression damping from the first 65% or so of the travel.  if you welded it up you would then have compression damping for the whole range of travel.  might need lighter oil in that leg.
the hole you drill in the gsxr compression shim stack does much the same thing, but it is smaller (1.3mm) and mimics having the damping adjuster open an appropriate amount.
from springs i have measured i'd put the s4 springs in the 0.80 kg/mm range, which is lighter than I would fit.  i'd lower the oil level though, and use 5 weight.
Brad The Bike Boy
http://www.bikeboy.org
Dirty Duc
The adjustable forks I put on mine were billed as coming off an ST.  They measured the same uncompressed as the Marzocchis that came off.
Same diameter as the Monster forks, so no mucking about with the triples.
cbcanada
Ok so I am leaning towards getting s2r1k forks because I won't have to fiddle with triple clamp boring issues
I will have linear springs put it. This is the better way to go right?
Can use my stock rotor and calipers on these forks?
Quote from: cbcanada on October 28, 2014, 07:33:18 AM
Better than what you have and probably worth it (depending on price and condition).
If the price is right it's not like you're going to waste money, since items like that 'easily' finds a new owner if you decide to take further steps later. Also; the S2R1000 forks are ready for quite a few levels of 'further steps' - including brake upgrades.
The S2R800 brakes fit straight on - no mods required.
brad black
#19
you may have misunderstood some points.
all the ss, monster, st and sport classic forks are the correct size, even 900ss from 1991.  but you need the 25mm axle and 65mm brake caliper spacing.  so any 43mm upside down fork from ss, monster (2v and 4v), st or sport classic.  the upper triple dia is 50mm, the lower 54mm on all.
forks that require triple clamp mods are sbk forks from 916 onwards, which are 53mm top and bottom.  the ohlins are 53mm top and 56mm bottom.  748, 749, 848, 916, 996, 998, 999, 1098, 1198.
the st forks have a linear spring around 0.83kg/mm, which is not too bad.  in an st they need more preload, but might be ok in a monster as is for you.  s4 and s4r forks are similar in my experience.  m1000 i don't recall, i don't have them on my list.  ss1000 are the only forks in all the 50/54mm range that have "good" internal valving.  but generally all the 2v monster and ss forks have crappy two stage springs.
so i'd say st, s4 or s4r.
if you were going to get them revalved to suit you, the non adj ones are actually better internally.  like these st2 ones: http://www.ebay.com.au/itm/Ducati-ST2-front-forks-/231364904381?pt=AU_Motorcycle_Parts_Accessories&hash=item35de6c45bd
Brad The Bike Boy
MonsterHPD
Quote
............... m1000 i don't recall, i don't have them on my list.  ss1000 are the only forks in all the 50/54mm range that have "good" internal valving.  but generally all the monster and ss forks have crappy two stage springs.
The Monster1000 has the same fork as the M900.
The ss1000 has a fork with correct hydraulic lay-out, but ridicilously soft shimming.
The "progressive" spring in the ss1000 has a spring rate of about 0.6 kg / mm for at least th first 40 mm of compression (my tester runs out of range above 40 mm compression).
Best potential result for the least (but some) effort in my personal opinion: ss1000 forks with upgraded shimming and linear springs. They are longer than the Monster/ST forks, so they only work on a Monster with clip-on bars since the stock bars are right over the fork legs.
Lots of advice on "best" solutions, I'm afraid ...  :-\
Monster 900-2002 (sold, alive and well in the UK), 749R / 1100 HYM combo for track days, wifes / my Monster Dark 800-2003 (not entirely "Dark" anymore and a personal favourite) , 50% of 900SSie -2000 track bike for rainy days-now with tuned ST2 motor and Microtec ECU. Also parked due to having been T-boned on track.
RonB
07 S2R 1000
brad black
springs for 43mm forks need to be around 38.5mm od.  generally racetech springs the first two # are the od in mm (roughly), the next two the length in cm.  so 32mm od, 340mm long.  the box says 31.7mm x 340mm.
and 0.80 is a bit light.  i'd be starting at 0.85 for a monster with someone on the light end of average.
Brad The Bike Boy
brad black
Brad The Bike Boy
cbcanada
Quote from: stopintime on October 28, 2014, 12:57:59 PM
What's would you consider a good price for the 1k forks?
cbcanada
Quote from: brad black on October 28, 2014, 02:05:40 PM
Great info... Lol just when I was decided in s2r1k you got me thinking again..
Okay I don't push my bike hard. I ride around city during week and the country on the weekends.. My main objective is stopping nose dives under braking and later on when I have more budget upgrading to 4 cyl. Calipers.
So keeping in mind budget and ease of Install..
St or 1k forks?
What if I got the 1k and put linear springs?
brad black
Quote from: cbcanada on October 29, 2014, 04:06:49 AM
St or 1k forks?
they're much the same forks, just with different springs ex factory.
Brad The Bike Boy
Quote from: cbcanada on October 29, 2014, 03:58:46 AM
Since the ST fork, ref Brad, has linear springs, it'll save you money over S2R.
I don't follow the North American market, so I can't tell you anything useful about pricing.
Gotham has an ST fork which looks ok - at $ 500.
http://www.ebay.com/sch/i.html?_odkw=ducati+monster+forks&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xducati+monster+s2r1000+forks&_nkw=ducati+monster+s2r1000+forks&_sacat=0
cbcanada
Will the ST forks will work with my current calipers and rotors without adjusting?
Quote from: cbcanada on October 29, 2014, 06:14:44 AM
Yes  [thumbsup]
