Tail Light hook up problems
Started by burt69er, July 12, 2008, 11:28:59 PM
burt69er
Okay I'm stumped and have run into an impasse.
I'm doing my tail chop on a 07 S2R 1K.  Tail is chopped CW kit on.  Hooked up the licence plate light it works
Hooked up one 1 LED signal with resistors it works with correct flash rate.
Put all three connectors on tail light it works but no high for the brake light.  Its a stock light.  I have tried every combination but can't get the brake lights to work.  There is a yellow wire, red wire, black wire.
I know I was a dumbass and didn't write down the order they were in when I took it off.
Blown fuse?  I haven't run the bike yet just turned the key to get the lights to come on.  Everything else works?
Suggestions?
