M900 Cylinder Head Assembly
Started by MonsterMadMarty, November 10, 2014, 12:47:01 AM
MonsterMadMarty
Today I've assembled the vertical cylinder head on my 93 M900.  So far so good..... Well, I think so!
Once assembled should I be able to turn the cam by hand? Everything just seem a bit too tight! From memory prior to pulling it all a part the closing rocket could be push down with a screw driver with a fair amount of ease, now it sit solid. What have I farked up?
Cheers in advance
Hard to tell over the internet, but if it turns with the rockers off, valve clearance.
monsta
yeah clearences are better to be a bit loose than tight.
when they are tight (closer) your putting extra load on the half ring.
either get another shim or sand it down some.
MonsterMadMarty
I think maybe as I had the valve reseated they will be sitting slightly higher and therefore the original clearance is now tight! Would that make sense?
Quote from: MonsterMadMarty on November 11, 2014, 06:37:52 AM
Yes.
Depending on how much material they removed it could be more than slightly higher.
MonsterMadMarty
Quote from: ducpainter on November 11, 2014, 06:48:23 AM
Yes.
Cheers again DP, that makes me feel better, I didn't fark up too badly  :D
monsta
that would make the opener tighter and the closer have more clearence. you should still re-shim.
(dont forget I have swags of shims if you need em...)
