Will these levers fit?
Started by lightspd, November 14, 2014, 07:41:55 AM
lightspd
Without going into my own stupidity, I have managed to break the little ball ends off both my clutch and break lever.  I don't have th funds to replace them with super nice ones, but wanted to ask if these(click here) would fit/work on a 2014 696?  Or would it just be better to wait and get a name brand later?
Thanks
lightspd
Probably should have made the url a bit clearer, but if you click on the word these, it should take you to the amazon page.
Skybarney
My buddy bought those exact levers off Amazon.  They are now purple (not black for a single summer of UV and the wiggle in the mounts a fair bit.
Why not just get some stock levers?  I bet a few of us have some around.
lightspd
Quote from: Skybarney on November 14, 2014, 08:58:00 AM
Thanks for the feedback.  I think I'll skip on them after hearing that.
I have small hands and just found that I prefer the shorter levers.  Figured if I'm going to spend money, even a  little, might as well try to get shorties.  I actually don't mind the stock's with the end's broken off too much, they are just a bit sharp at the break point.
thorn14
I purposefully bought a broken clutch side and filed the end to a smooth point, then powdercoated it black.
Ok fine, I did it for the adjustable lever, and I'm cheap, but it works.
M620 turned M800 but then back to M620 after the M800 died at 110k, and now to Multi 1000.
Skybarney
Like Thorn said.  A little bit of time with a grinder, drill and a Dremel and you can likely make those levers short and kinda cool looking.  [thumbsup]
Made this at home with the above tools.
lightspd
^^ Nice work.
I live in an apartment complex, so I'll have to see if a friend has some tools and space I can borrow.
Even on setting 4, I wish the levers were slightly closer to the grips.
So many things to do to the bike, so little money. :)
djomlas
just buy them in silver if you're worried about discoloration.
i have a set thas 4 yrs old and still looks black (vortex)
and set of aftermarket ones like that, from eBay, in all black, and they still look black as well....it is really nice to be able to adjust them, heck for $20 can't go wrong even if you HAD to replace them every year, thy are held with one bolt and thats really it for the most part. i just put on a set and took no more than 5 mins total.
S2R
Rizoma rearsets, full Zard CF dual exhaust, Rizoma clipons, Sargent seat, 999 shock, golden brembo calipers/rotors upgrade,adjustable levers and billet grips, some CF (belt covers, heel guards, chain guard sprocket cover, fender, bellypan), integrated R6 tail light, bar end mirrors
other bikes in garage: 08 hayabusa, 06 hayabusa, 07 zx14, 07 r6, k6 gsxr1000, r1, 08 zx6r, triumph speed triple,2 vespas and a ruckus, its an obsession
SpikeC
Were I in your position I would find a way to save the old levers. As I have access to a large amount of tools and work space that is easy to say.
I think that you should buy the best that you can afford. Like they say at Langlitz, "the joy of low price is not as long lived as the pleasure of quality". Or something along those lines! ;D
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
Rudemouthsky
My black China levers purpled and wobbly'd pretty fast as well...then I purchased shorty silver/clear and they look good as new 3 years later. And I never had a prob with "wobbliness" in the shorties, only the standards. Still the best $35 I ever sent to China, their levers are a great value.
oldndumb
Quote from: Skybarney on November 14, 2014, 01:26:37 PM
Maybe I am too literal, or our terminology is not in agreement, but a grinding wheel is not safe for use on Aluminum. I am thinking grinding wheel, and you might have been referring to a small grinding bit for a Dremel. If you indeed used a grinding wheel, it most likely loaded up with Aluminum and can be out of balance.
Skybarney
oldndumb
Then, understand that if you see shiny smears of Aluminum on the wheel, it is out of balance to a certain degree. The significance/consequence is relative to how much material is on the wheel and how close it was to being in balance to begin with.
If it were me, and I could see Aluminum on the wheel, I would try a wheel dresser to return it to a safer condition.
