January 15, 2025, 04:04:54 PM *
News: Please Help
Author Topic: S2r 100 belly pan  (Read 5654 times)
cody_clark
« on: November 22, 2014, 07:13:49 PM »
I just received my belly pan from a guy on ebay and I got a picture for you all to see.
I,think it really pulls the look together
Duck-EZ
« Reply #1 on: November 24, 2014, 01:03:30 AM »
 bacon waytogo bacon
I thought one was suppose to stick on a thermal barrier to keep the CF from toasting.
2006 Black N Tangy S2RS
cody_clark
Re:
« Reply #2 on: November 24, 2014, 02:29:49 AM »
It has a thermal barrier on the business side of it I just didn't snap a pic of that.
Duck-EZ
« Reply #3 on: November 28, 2014, 08:59:42 PM »
Ah! Carry on my good sir!
 chug
hackers2r
« Reply #4 on: November 29, 2014, 11:34:41 AM »
I believe that is mounted incorrectly.  I checked through pictures of similar pans and it seems yours is mounted way too low.  I predict it is going to scrape while riding at that height.  I had purchased the same style one a while ago for my S2R 800 and had problems with the mounting points as I believe it is meant for the older Monster mounting points.
cody_clark
Re:
« Reply #5 on: November 29, 2014, 11:59:21 AM »
Well its as high as it will go with the udder there. And I was looking and I can get it a little higher but I'll have to do some trimming. And I checked out motowheels website and it said that this belly pan,would mount to my monster
cody_clark
Re:
« Reply #6 on: November 29, 2014, 12:04:07 PM »
And I just measured it I have a good 6 to 7 inches of space underneath before anything hits.
Feral 859
« Reply #7 on: November 29, 2014, 12:32:11 PM »
Correct.
thorn14
« Reply #8 on: November 29, 2014, 12:43:35 PM »
Both of my stock headers have scrapes from previous owners bottoming out on things. A speed bump would likely be a bad experience.
Looking at the bottom of the belly pan, you should see the x pattern for the older style headers which go on the left and right side of the bike instead of the S2R right side stacked exit.
M620 turned M800 but then back to M620 after the M800 died at 110k, and now to Multi 1000.
cody_clark
Re:
« Reply #9 on: November 29, 2014, 02:07:10 PM »
Well I guess I'll go to modifying it so it'll fit up higher.
thorn14
« Reply #10 on: November 29, 2014, 02:19:48 PM »
It should just be the udder area that's messing it up.
Feral 859
« Reply #11 on: November 29, 2014, 02:32:36 PM »
I don't think it's made for the '100'  Cheesy
hackers2r
« Reply #12 on: November 29, 2014, 09:55:28 PM »
I absolutely agree...anything can be made to work...that's what makes things unique.  I was just advising against riding it the way it was mounted as it would likely result in damage to the new piece if not more due to scraping.  I ended up returning mine as the modifications needed were pretty extensive if I remember, including creating a mounting point on the left side of the bike that the S2R models didn't have.
cody_clark
Re:
« Reply #13 on: November 30, 2014, 05:34:26 AM »
No I completely understand. Thanks for looking out Smiley I appreciate it and I'll go look at it today and do some trimming and I'll post another pic when I finish Smiley
Skybarney
Fako
« Reply #14 on: December 01, 2014, 04:17:10 PM »
Don't forget to wear a mask when cutting it or sanding it.  CF is nasty on the lungs.
