October 11, 2024, 05:18:33 PM
Squeaky Front End from 2007 S2R800??
Topic: Squeaky Front End from 2007 S2R800?? (Read 914 times)
Crazy Canadian
July 13, 2008, 10:35:02 AM »
Hi guys, I've been noticing a squeaking noise coming from my front wheel that is getting progressively louder. This is at parking lot speeds and such, slowing down for a light in the city, etc. It sounds almost like bearings? I'm getting a little concerned. I'd hate to be riding along and have the front wheel sieze up or fall up or something. I still have warranty, so i'm thinking of bringing it in, but it begs the question, should I be lubricating anything other than the chain on this thing? I never have, and I've ridden in rain quite a few times.
2007 S2R 800, 14T Front Sprocket, Simple Tail Chop, SpeedyMoto Sliders, Arrow Steering Damper, Rizoma Reverse Retro Bar End Mirrors, Arrow Full Exhaust, Crazy Ass Driver.
Hedgehog
Re: Squeaky Front End from 2007 S2R800??
July 13, 2008, 12:06:35 PM »
It might be the brake pads, but it's probably a wheel bearing. Get it looked at.
Crazy Canadian
July 13, 2008, 02:45:21 PM »
I know the sound the brakes make when you apply them and that's not it. It's not constant either and seems to go , Squeak, squeak, squeak and increase or decrease in frequency depending on speed. I'll take it in. So no maintenance I should look at re lubrication other than chain, oil and cleaning? I am assuming everything is sealed up tight in there. Thanks
clubhousemotorsports
July 13, 2008, 06:29:22 PM »
If the noise is changing with wheel speed it is not head bearings.
Look at your wheel bearings and also look at your rotors, a bent rotor will just contact at the high spots. inspect the rotor surfaces and watch for extra shiny spots . If the wheel is not centered the high spots could be contacting the caliper body.
anything change about the time the noise started? tire change?
