Truckers Monster Rebuild
Started by truckinduc, July 13, 2008, 12:33:26 PM
ChrisH
Dude, you have very marketable skills. I hope that you are planning on doing something creative like this once you finish school. You could likely make a good living building custom cars or bikes. Can't wait to see how this ends, I imagine it will be amazing. Good luck with the knee!
2010 Monster 696
2005 Honda Ruckus
1985 Honda Spree
-Austin Texas-
truckinduc
thank you. I do plan on it some day.  Its my goal to run my own shop.
truckinduc
BTW I need a 12mm motor mount bolt if anyone has one they can get rid of.
truckinduc
started mounting the motor to the table.
and another shot of these things cause its the only actual progress of the bike lately.
truckinduc
tube fitting. aluminum for mockup.
I was planning on bending the tube right at the joint, but I think ive decided not to. Its only 4.5 degrees of angle difference. shouldnt hurt to get a good tight fit and slug it and weld it.
Here is where I run into a problem, like I knew I would.
The tube will interfere with removing the side cover.
I guess thats why the superbikes frames are like this.  I dont like it though cause this is the furthest back my frame is, no shock mount behind that motor mount.
truckinduc
other side notched up.  No problems here.
1KDS
Looks like you may be able to sneak that case cover out with the frame there
Every bike I've ever owned.
hadesducati848
... was this thread always called "Truckers Monster Rebuild " ?
or have i just had waaaayyyyyy to many beers?
great job so far, cant wait to see things start to come to gether
djrashonal
no, it was called something like "way to modify your bike to make it unique" or something like that
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
truckinduc
Ya I changed the name. Im gonna have the thread moved to general monster discussion also.  Its not really a tutorial because I doubt many other members are going to cut up a perfectly good monster frame for the fun of it.
So keep drinking Hades.
truckinduc
here it is at a 56" wheelbase.   Barely enough room for the shock and the linkage. If I made an entire frame id move the front wheel as close as possible to the head to get a longer swingarm.
Feel free to design a swingarm. I have mine pretty much designed, I just like to see what others come up with.
truckinduc
why not try to figure out a under engine shock setup
truckinduc
Thats what I was planning on doing months ago, but im pretty much dead set on a unit pro link style now.
truckinduc
difference between the old 10mm frame to motor bolts and the new style 12mm bolts.
I had to turn down the flange slightly to get the bolts to fit the frame.
old vs new
it fits
and the crack I need to fix.
