Truckers Monster Rebuild
Started by truckinduc, July 13, 2008, 12:33:26 PM
truckinduc
narrowing the cases further. I have to make a tool to get the surface flat and true.
and I spent 2 hours bead blasting what little frame i have left.  Ill remove the rest of the unused tabs and smooth it in general.
The final finish of the frame will be clear powdercoat. Im not sure If I should leave it raw bead blasted or sand the frame first to give it direction. what would you do?
Kopfjäger
Quote from: truckinduc on August 22, 2010, 07:25:54 PM
Raw, just my .02
Raw.  It might look cool with a raw metal tank too.
Grrrly
#184
I would definitely sand it!  If you leave it bead blasted and then clear it, it's going to end up looking like a regular silver frame and the "raw" effect will be lost.
My tank is raw/polished and clear powder coated, the powder process will darken it just a little as well.
Just to give you an idea:
I polished my steel tank and then matted the sides using an orbital sander.
Before the powder coat
And after
There's a monster owner at my "local" track who has a cleared raw frame as well, and he left a pattern on it.. definitely adds to the effect in my opinion.
link to my original photo wherecan see details a little better: http://farm4.static.flickr.com/3612/3626777234_d3647e21a8_o.jpg
as always I'm lookin' forward to your product.  [thumbsup]
The Evil Twins:
Urban Assault Vehicle: 2002 Duc M 6/900 Industrial Edition
Track Weapons: 2004 Suzuki SV650, 2009 Kawi ZX-6R Monster Edition
Celli
Quote from: truckinduc on August 19, 2010, 08:01:05 PM
here it is at a 56" wheelbase.   Barely enough room for the shock and the linkage. If I made an entire frame id move the front wheel as close as possible to the head to get a longer swingarm.
Feel free to design a swingarm. I have mine pretty much designed, I just like to see what others come up with.
I've been inactive on this forum for a while. So now I see all these new projects. Impressive! I can't wait to see it finished!!!! Great job!!!! Celli  [thumbsup] [thumbsup] [thumbsup]
Ducati Codatronca: Concerto Molto Vivante!
Celli
truckinduc
Quote from: IndustrialGrrrl on August 23, 2010, 06:33:04 AM
And after
Ya  im pretty sure im going to hit it with some aggressive scotch bright by hand to give it a subtle brushed look them clear it.
I love the exposed brass in your tank. I still havent decided if im gonna make an aluminum tank or a fiberglass tank yet.
truckinduc
i tried scotch brite and you really cant tell it did much, so out came the sandpaper.
this is raw bead blasted. looks like silver metallic paint.
this is sanded in a single direction
hadesducati848
i like the sanded in single direction look  [thumbsup]
truckinduc
I just removed some unused tabs from the frame.
It weighs 13lbs right now.  I bet it will be right under 16 when finished.
Im shooting for 10lbs for the swingarm, minus linkage.
truckinduc
started on my swingarm jig today
truckinduc
Does anyone know the swingarm angle of the SBK models?
1KDS
848/1098
QuoteWhat You Actually Get Off of the Showroom Floor
•Trail 91.5mm
•Swingarm angle 7.8deg
•Steering head angle 24.7 deg
•Front ride height 711.5mm
•Rear ride height 230mm (measured with DOS tool)
•Swingarm length 505mm
•Wheelbase 1447mm
•Weight distribution 49.5f/50.5r
•Weight 401lb
http://www.ducati848.net/forums/showthread.php?t=12513
Every bike I've ever owned.
truckinduc
thank you.
christmas came early
