truckinduc
« Reply #345 on: September 26, 2010, 05:49:19 PM » |
version 2.0 Notice the ample room for a socket, all .200" of it. also notice the backside is milled. Just need to make the other one and the adjustment tool.
Ahks
« Reply #346 on: September 26, 2010, 06:21:04 PM » |
« Reply #347 on: September 26, 2010, 06:33:17 PM » |
how are you going to turn the eccentrics in the swingarm? Are you going to mark degree indicators on them for matching?
truckinduc
« Reply #348 on: September 26, 2010, 06:39:36 PM » |
ill be making a special tool to turn them. as far as indexing them im not sure yet.
truckinduc
« Reply #349 on: September 27, 2010, 08:38:21 AM » |
QUESTION... Has anyone upgraded the regulator rectifier on an older 900 motor? Im pretty sure it will swap with another 3 wire unit like I have on other jap bikes. None of my other bikes run their stock R/R. Id like to replace it with a smaller more heavily finned unit, as well as step up the wire size.
I dont care about plugs as ill be building my own harness.
greenmonster
« Reply #350 on: September 27, 2010, 01:02:40 PM » |
M900 -97 MTS 1100s -07
truckinduc
« Reply #351 on: September 27, 2010, 03:04:28 PM » |
right now its around 14 lbs. It should be around 16 lbs finished and braced up.
« Reply #352 on: September 28, 2010, 02:42:03 AM » |
Ducatl
« Reply #353 on: September 28, 2010, 07:25:05 AM » |
Wasn't somebody here talking about building a much smarter, much smaller, reg/rec? where is that thread anyways...
« Reply #354 on: September 28, 2010, 11:14:02 AM » |
suzyj in tech... http://ducatimonsterforum.org/index.php?topic=38021.msg672254#msg672254
« Last Edit: September 28, 2010, 11:18:50 AM by humorless dp »
"Once you accept that a child on the autistic spectrum experiences the world in a completely different way than you, you will be open to understand how that perspective is even more amazing than yours." To realize the value of nine months: Ask a mother who gave birth to a stillborn. "Don't piss off old people The older we get, the less 'Life in Prison' is a deterrent.”
truckinduc
« Reply #355 on: September 28, 2010, 04:12:46 PM » |
finished the new Eccentrics. What do you think? better pictures soon
Mojo S2R
. Dark Mojo .
« Reply #356 on: September 28, 2010, 06:04:19 PM » |
Very nice. Those look sweet.
truckinduc
« Reply #357 on: September 28, 2010, 06:16:44 PM » |
« Reply #359 on: September 29, 2010, 03:33:57 AM » |
better pictures is that lock screw sufficient to prevent the axle from turning? i assume it is.
Check out my oil filter forensics thread! Offended? Click here"Yelling out of cars, turning your speakers out the window to blast your music onto the street, setting off M-80 firecrackers, firing automatic weapons into the air—these are all well and good. But none of them create a merry atmosphere of insouciance and bonhomie quite like a revving motorcycle.
