Truckers Monster Rebuild
Started by truckinduc, July 13, 2008, 12:33:26 PM
adgergewh
Quote from: truckinduc on September 29, 2010, 01:00:01 PM
I rubbed them with graphite then put a piece of paper on them and transfered it to the paper.
Then I can measure the centers with calipers on the paper.
that theoretically is an incorrect method of measuring them unless the bracket you are making is going to bend in the exact way the paper did. you should get too long of a distance by pressing the paper. you should do what was said before and use some sort of spacer to even the planes, whether it's a dowel or washers but you need to even out the planes and then measure center to center.
TAftonomos
I wish you would post a dimension of these holes....I've been wanting to have a engine stand adaptor made up/bent out of steel but never got around to measuring out the holes....
truckinduc
Quote from: adgergewh on September 29, 2010, 02:55:26 PM
Actually the paper didnt bend at all because the 3 Boss's are all on the same plane.  So It did work.
truckinduc
Quote from: TAftonomos on September 29, 2010, 04:52:27 PM
Sure I will. Tonight I should be able to confirm the fitment. If it fits ill draw up a print of the locations.
Then Ill do the other side of the motor with the 4 holes. It may be a tad harder.
truckinduc
mendoje
Here's a couple ways.  You can use or make some plug gauges, which are just dowels turned to fit precisely fit the holes, then measure the distances to the outsides of each pair, subtract the radii, then trig it out.
If you're going to make some precise fitting plugs, you could also make them into transfer punches by turning some points on the ends.  With the transfer punches in the holes, hold some sheet or plate stock against them and give it a tap with hammer.
Quote from: truckinduc on September 29, 2010, 12:04:19 PM
Anyone know the spacing of these holes?  Its kinda dificult to measure them.
2003 M800Sie / 2004 BMW R1100S / 1981 BMW R100RS (Sold) / 1977 Kawasaki KE100 (1st Bike :))
http://ducatimonsterforum.org/index.php?topic=27788.0
truckinduc
Yep I thought of that method too. That would be my next course of action if this test plate did not work.  The paper transfer method is actually working out pretty well.
truckinduc
fit perfectly
and made Ducati special tool  #477 the cam nut removal tool
truckinduc
other side,  one hole is slightly off, the one on the far right. No big deal.
Howley
Five days and that's all you've done??? Hurry the hell up!
truckinduc
DucHead
#386
 [laugh]  I don't think that video defends you in any way!   [laugh]
Beautiful horses!!  ...and they had the good sense to get out of the way!!   [laugh]
flanman
Can we get some pics of that bike?  ;D
